A wannabe no more
My car is not well situated for good interior shots, but if you check out Savageese's YouTube video "Take It to the Grave," mine looks exactly like that one except for the flies.
I read something like this and it causes enough concern that I will never own a car with a pano again. I owned a 2014 Hyundai with one - never had a problem but I knew the risk was there. My shade was closed most of the time anyway.
It is not as big an issue as you're making it seem. It's extremely rare for a modern pano roof to explode. It's not impossible, but not likely.
The panoramic sunroof is the one option I most wish I didn't get. The added weight (probably 150 to 200 pounds) makes the car much less agile (worsens handling), not to mention slower acceleration, worse gas mileage, longer brake distances and worse overall stability. I notice the difference when I get a loaner.
I am glad my ES300h has the regular moon roof. I don't like how the panoramic roof opens up on the ES. Over 99% of the time I don't use it anyway in ES. I have a Miata for the top down experience and I drive it top down 99% of the time.
I guess you missed the part where I said "statistically you'll be fine". But don't kid yourself it happens more often then you might believe.
pano roof comes with its set cons besides what David Z already mentioned. If you live in a hail prone area or visiting that territory it is something to consider. If you do a lot of high way drivings there is always the chance a flying rock is going to take it out at the most inopportune time. Like having a moon roof you also have to clean the drainage holes occasionally as the car age if you don't want to water getting into the car. Should you park underneath trees regularly you have to perform that maintenance more often.
All tempered glass has the possibility to be defective and self destruct. My sister had a minivan several years ago where the rear side window did that 2x over the 5 years she owned it. Also, more regular sunroofs explode than pano's, due to their being more of them out there
