Nitrogen Filled Tires
Old Apr 25, 2023 | 10:23 AM
  #31
mikemu30's Avatar
mikemu30
Originally Posted by bc6152
Very simple: You press a button on your dash to see what your tire pressure is. If it's low you find a local Quikcheck with a free pump to level it off. I find that my tires change pressure by about + or - 1 pound. So I don't worry... And I'm not sure but I think that the TPMS will notify the driver if the pressure goes too low. I put 78% Nitrogen into my tires...
Yes indeed you get the dreaded warning light. Most times, it's due to a nail in the tire at least in my case
Old Apr 25, 2023 | 12:37 PM
  #32
UTChE96's Avatar
UTChE96
I offer free fill ups with 79% Nitrogen for a 21% discount.
Old Sep 1, 2023 | 05:33 AM
  #33
mj1pate's Avatar
mj1pate
6th Gear
Much ado about nothing...
Shakespeare 1599...
I seriously respect the point of view. Let me illustrate how it can be much ado.
We had our first mid-Atlantic cold snap of 57 degrees this morning after temps ranging from mid-80s to low 90s. The Tacoma atmospheric-filled tire sensors shouted from the dashboard. Sure enough they were 3-4 lbs low. Same for the 80s Porsche. I checked the Rx350 and it’s nitro-filled tires were right on. But I had to move the RX out of the way to get the Tacoma nearer the air tank and the Porsche, before I could drive the daily Tacoma.
For those of you in the mid-Atlantic with “meh” nitro-filled tires used as your daily, I hope you enjoyed hopping right in, heading right off to work or the golf course.
oh… geez, it’s mid-90s in the middle of the week. I’ve got to remember to deflate that Tacoma.
Old Sep 1, 2023 | 07:00 AM
  #34
mikemu30's Avatar
mikemu30
Just top them off when it gets cold. Really is much ado about nothing. I keep an inflator in my trunk. It was 51° this morning and I didn't even get the light because I topped them off a few weeks ago
Old Sep 1, 2023 | 07:01 AM
  #35
bc6152's Avatar
bc6152
After driving two blocks the pressure is back...No need for nitrogen filled tires when the air you're breathing is 78% N. Dealers scam unaware people into paying for it...
Old Sep 2, 2023 | 12:32 PM
  #36
mikemu30's Avatar
mikemu30
My daughter just bought a new X5 - she showed me the draft deal with $399 for nitro. She just saved 399 of course as she had no idea.
Old Sep 2, 2023 | 04:07 PM
  #37
bc6152's Avatar
bc6152
$399.00 !!! Ouch! You're a good dad Mike... She should treat you to dinner...
Old Sep 3, 2023 | 07:55 AM
  #38
RobertJay's Avatar
RobertJay
I have nitrogen filled tires. Can I start just filling them up with air instead of nitrogen?
Old Sep 3, 2023 | 08:02 AM
  #39
LS500Fan's Avatar
LS500Fan
Yes, normal air is ~78% nitrogen anyway. I've done that on my truck, just use regular air to top up.
Old Sep 4, 2023 | 10:33 AM
  #40
LexFinally's Avatar
LexFinally
I mean that's precisely why we have TPMS systems. I also store an electric pump in the trunk which I almost never use because the local Quikchek has two FREE airpumps with digital set points.
You're lucky. In my area, every station with air gouges you two bucks a pop to use it.
Old Sep 4, 2023 | 10:35 AM
  #41
LexFinally's Avatar
LexFinally
I got the light when I fired it up a couple nights ago in the middle of nowhere on a holiday weekend. Scared me until I remembered how to access the dashboard display and saw it was because one tire had dropped to 29 PSI. Talk about a hair trigger. That kind of warning does more harm than good.
Old Sep 4, 2023 | 11:48 AM
  #42
Mike728's Avatar
Mike728
Depending where in IL you are, just take it to a Discount Tire and have them filled. If needed, also have them rotated. All for free!
Old Sep 4, 2023 | 12:04 PM
  #43
mikemu30's Avatar
mikemu30
You get used to it or you pump up before the colder weather sets in. We're having a heat wave in Sept here in the NE so I won't have to worry about so soon😉
Old Sep 4, 2023 | 09:20 PM
  #44
EmeraldLexuSC3's Avatar
EmeraldLexuSC3
Extra for Nitrogen??
I get my fill free of charge at Costco and when I buy my Tires.
They also have a self Tire inflation station out in the parking lot outside their Tire Center.
Costco Tire Inflation Machine
You put in the recommend psi and it let's you known when it's filled.
Old Sep 5, 2023 | 06:56 AM
  #45
LexFinally's Avatar
LexFinally
Wait, even if you didn't buy your tires there?
