Wind noise inside cabin
@lovemore... not sure if you had the problem resolved but there is a technical bulletin associated with the rear quarter panel glass on the drivers side. The dealership just replaced mine and the noise I was having (that sounded just like what you described in the OP) disappeared. Very pleased with the much lower noise level in the car! Thought you and others might like to know.
how is the wind noise, still holding up well? I have a 2023 premium and at speeds of around 45+ it sounds like a window is cracked open. I want to reach out to the dealer with a little ammo. Do you happen to have the technical service bulletin number?
Wind noise after the fix was reduced significantly and remains so today. I find the ride quiet now. Not sure if I have the bulletin number, but a quick search online resulted in this TSB... https://www.tsbsearch.com/Lexus/L-SB-0031-22. Likely the one they used to repair my window.
Thanks for resurrecting this. I have this problem. It's intermittent and not that annoying but would like to get rid of it. I'd prefer not to take the car to the dealer so I think I'll see if I can fix it myself. Knowing the likely source of the problem is half the battle with stuff like this.
