HVAC making noise
Old Jan 30, 2020 | 07:22 AM
Seankim513's Avatar
Seankim513
Originally Posted by drbranto
For several months, I have been hearing a chirping / gurgling noise when the AC is on. When I turn the AC off, it goes away. I have also determined that it is not the fan as when the heater is on with the AC off, the noise is not there. It is not very loud and the radio easily masks this noise. Nevertheless, I plan to have it serviced soon in hopes of resolving it. Has anyone else experienced this noise on their 2019 ES350?
thats same condition i had.you need set up appointment. I had 2 dealer before i got fixed.
they do not want fix.just pull other es model if they making noise when ac on.dealer tell you normal.i had this problem. And with dealer loaner car.loaner make ac noise.out es model has 2 origine. One japan .other one usa.i am not telling made in us model are bad but they just dont have good skill as japan factory .once again you need stop afew dealer to fix this problem.
i think i can fix statement. But not ac leaking problem my self.
i hope you fix ac leaking problem. Good luck
Old Feb 8, 2020 | 06:43 PM
chkk's Avatar
chkk
I am having the same issue on my ES 350 2020 as well! But it just went away when I checked my car again later, still unsure about the cause but will have a service soon in two days.
Old Feb 8, 2020 | 06:54 PM
chkk's Avatar
chkk
Also I found this video of the noise online
which happened to be the same as mine. Can anyone confirm this is the same sound to cause the issue? Thx a lot!
Old Feb 9, 2020 | 07:56 AM
drbranto's Avatar
drbranto
Default HVAC Noise
Originally Posted by chkk
Also I found this video of the noise online https://www.youtube.com/watch?v=qD9bHLRtrxU which happened to be the same as mine. Can anyone confirm this is the same sound to cause the issue? Thx a lot!
This is very similar to the noise I hear intermittently. It's frustrating to not be able to demo this noise to the dealer as it occurs intermittently. I had an appointment at the dealer but the day and time I went in, the noise had stopped. It has not gotten worse - but it has been there for months (I have a 2019 ES). Because the noise is subtle and intermittent, I am concerned that it may be a while before I can get the dealer to even acknowledge the issue never mind actually resolve it. I am hoping that some one on this site would provide a solution based on their experience with a dealer. I certainly will provide my experience should I get it diagnosed.
Old Feb 9, 2020 | 10:23 AM
chkk's Avatar
chkk
mine happens intermittently too. Maybe it’s temperature related. I think OP post a solution to his own. I’m going to try mentioning that when teaching out to dealership. Good luck.
Old Feb 10, 2020 | 05:58 PM
chkk's Avatar
chkk
Quick Update:
I went to my dealership today. Unfortunately, they could not find anything wrong or abnormal in my car, since the boiling noise was gone today. And they refused to take a look at the solution OP posted earlier, saying that different cars have different problems, spending over 3 hrs on inspecting the car, pretty much the same as pre-delivery check, including bleeding all the fluids to see if there's any air bubble. I guess I'd just have to wish the noise would not come back again....or could be reproduced at the dealership
Old Feb 11, 2020 | 08:34 AM
kalel2127's Avatar
kalel2127
Since I read this thread I have been paying more attention each morning. Today, I actually heard the faint sound everyone is talking about. I can only hear it when the music is off which is probably why I have never heard it in the past. Every time I turn on my vehicle the first thing I do is pick a playlist to cruise to. While the vehicle was on I turned the air off and on a few times until the noise disappeared, really disappointed in the quality of Lexus.
Old Feb 11, 2020 | 12:35 PM
chkk's Avatar
chkk
Is yours like bubbling/gurgling sound? Mine does not appear constantly and dealer said everything is fine.
Old Feb 11, 2020 | 01:58 PM
kalel2127's Avatar
kalel2127
Yes, I'm debating if I should take it into the dealership since more than likely they will just say everything is in fine and I will just waste my time.
Old Mar 2, 2020 | 11:01 PM
Seankim513's Avatar
Seankim513
i really hope your car get fixed.
i had lease . I dont need to be worry much as some one own this es.
try to set appointment afew dealer .check YELP to how they work.
better yelp rating.always good.
Old Mar 9, 2020 | 09:24 AM
ia2denver's Avatar
ia2denver
Default Same issue here - disappointing
I have the same issue. Second reason I’m disappointed with Lexus. Think it’s a defect but hoping it doesn’t affect functionality. Good thing I bought the extended warranty. (First reason is brakes squeaking)
Old Mar 9, 2020 | 10:06 AM
Seankim513's Avatar
Seankim513
Default before basic warrantee
fix it before basic warantee expire.
expanded warantee may not cover AC gas and joint leaking.
job looks simple but thats big job.
take a look one more time picture i posted.
its cost you .more than $1000.
Old Apr 9, 2020 | 09:49 AM
Seankim513's Avatar
Seankim513
you need check dealer now.
problem are low ac gas and ac line joint leaking. you have low AC GAS now.
check picture i posted.
extened warrantee not cover bumper to bumper. you will need to pay oil gas gasket ect
Old Feb 13, 2023 | 05:26 PM
Taharalove's Avatar
Taharalove
My 19 ES 350 is making the same noise as the youtube video linked above. Is there a TSB or a fix out for this that I could point them to?
That youtube video says: "UPDATE: There is now a fix for this. Just tell your Lexus service and they will know what to do."
Ptzes350
Apr 23, 2019 05:40 PM
esucaris1
Aug 17, 2009 07:10 PM
calboy76
Jan 19, 2009 11:43 AM
Din
Jul 7, 2002 09:17 AM
