ML audio system revision
Old Jul 24, 2019 | 08:20 AM
  #46
Tidal is well worth it IMHO. If I think about all the other worthless junk I spend $20 on in a month, I really enjoy the high quality music and getting the most out of my ML audio I paid a lot for.
Old Jul 24, 2019 | 09:12 AM
  #47
Mike728's Avatar
Mike728
How are you connecting your phone to the car? I believe Lexus is still using the SBC codec, which would make Bluetooth negate any audio quality improvements.
Old Jul 24, 2019 | 09:28 AM
  #48
I connect using USB. Notable improvement over BT
Old Jul 24, 2019 | 09:38 AM
  #49
Mike728's Avatar
Mike728
Interesting, I had no idea your LS could recognize a phone plugged into the USB port. I thought that was only for iPods and memory sticks. Does it work with both Android and Apple phones?
Old Jul 24, 2019 | 10:10 AM
  #50
Nope, when it’s plugged into the USB plug in the console the car treats it as a USB music player. Your ES works the same way, so does every other car I’ve had with a USB input.
Im sure it’s the same with Android.
Old Jul 24, 2019 | 10:52 AM
  #51
Mike728's Avatar
Mike728
So, you can play music through the Tidal app via USB? I thought you were limited to only locally stored music on your phone.
Old Jul 24, 2019 | 12:15 PM
  #52
kalel2127's Avatar
kalel2127
Originally Posted by DavidZ
I Googled "Tidal download" and there were sites that seem to describe ways to download music files. I didn't dig deeper because I'm not ready to do it yet. Ultimately, I would like to copy the lossless music files to a USB flash drive.
You may download music to your mobile device but you can't transfer that music to a USB drive because you don't own the music. Tidal gives you access to listen to said music as long as you continue to pay the monthly subscription. As soon as you stop paying you will no longer have the ability to listen to the songs you downloaded.
Otherwise, none of the streaming companies would be able to make a profit. Everyone would just download the music they liked and discontinue the service.
Old Jul 24, 2019 | 12:25 PM
  #53
bc6152's Avatar
bc6152
So to clarify, there's no way to subscribe to Tidal (or any other music service) without using BT or, as Steve states, by using USB input in the car to play through the vehicle radio and using massive amounts of phone data. Correct?
Old Jul 24, 2019 | 12:39 PM
  #54
kalel2127's Avatar
kalel2127
You can download music from Tidal to your mobile device while on WIFI in order to avoid using cellular data. Once downloaded to your mobile device Tidal doesn't require cellular data usage.
I have unlimited cellular data usage but prefer to download the music to my mobile device because the cell service in my area is horrible and would cause the music to stop. I downloaded over 50 gigs of music to my mobile device which are separated in about 20 different playlists.
Old Jul 24, 2019 | 12:59 PM
  #55
Mike728's Avatar
Mike728
So, when you connect your phone to the car via USB, how does it seperate the Tidal downloads from your regular downloads? And all this is visible on the headunit's display?
Old Jul 24, 2019 | 01:15 PM
  #56
kalel2127's Avatar
kalel2127
By opening the corresponding app. Yes, the track, artist, album, album art information is visible on the screen.
Carplay image
Old Jul 25, 2019 | 04:31 AM
  #57
nsaldanh's Avatar
nsaldanh
I've tried multiple Android devices (Onkyo DP-X1 MQA player that uses Android as the base OS and a T-Mobile LG V30) the car's head unit will not recognize an Android device. Neither an LS460 nor an LS500 recognize these devices.
Old Jul 25, 2019 | 04:32 AM
  #58
nsaldanh's Avatar
nsaldanh
Yes. You can either stream Tidal or play cached songs. This works both on Bluetooth and USB for an iPhone.
Old Jul 25, 2019 | 08:31 AM
  #59
95bat's Avatar
95bat
That may be because you have to tell Android devices what to do with the USB connection. It might be set to charge instead of act as a music device.
Old Jul 25, 2019 | 09:24 AM
  #60
Mike728's Avatar
Mike728
Have you gotten it to work with Android? I haven't had a chance to try yet in the 7th gen, but it does not work in the 6th with ML. I'm hoping they corrected that oversight by now.
