Help!
Old Apr 9, 2025 | 09:27 PM
Thomaslexus's Avatar
Thomaslexus
Default Help!
This has been a hectic last two years. Had a terrible back injury at work. Gained 40lbs because of the injury and stress. Cannot work or work out without excruciating pain.Yesterday I was diagnosed as a 7.1 a1c diabetic because of not being able to work no exercise limited mobility. Hard to take pain killers because Im afraid to mix pain pills with my Xanax I take from panic attacks. Friday I have to drive 2hrs to see a spinal specialist. Will this malfunction light be ok? Light illuminated while running errands. Car seems to be in normal operation but light is freaking me out.
Thanks for any recommendations,
Old Apr 9, 2025 | 10:04 PM
ESh's Avatar
ESh
Drive it, don’t worry. Just do not turn on the radar cruise control.
Old Apr 10, 2025 | 05:37 AM
edbro's Avatar
edbro
Was this a one time occurrence? Sometimes, these kind of glitches go away after tuning the car off and then on again.
Old Apr 10, 2025 | 07:00 AM
Thomaslexus
Yes I waited till I got home. Pulled in the garage. Turned the car off and then back on and the light was gone
Old Apr 10, 2025 | 08:12 AM
edbro's Avatar
edbro
Glad to hear. If that doesn't work next time, try slapping the side of the car fairly hard. That used to work on my old tube TV!
Old Apr 10, 2025 | 08:19 AM
Thomaslexus
lol I remember those days quite well!!!
Old Apr 10, 2025 | 12:57 PM
losiglow's Avatar
losiglow
Lane Tracking Assist error. If it comes back, try cleaning the windshield spot where the camera is - top middle section. It could just be that the camera can't see the road adequately.
Old Apr 11, 2025 | 06:12 AM
Lesley248's Avatar
Lesley248
Hope all gets better for you
Old Apr 11, 2025 | 02:08 PM
dougdangger's Avatar
dougdangger
It's only 1 dash light.
German car owners be like, "Hold my beer."
Old Apr 12, 2025 | 07:15 AM
es250fsport's Avatar
es250fsport
Theese warnings are a little aggressive though I found. You cannot get rid of it.
Yes I know there is an error and you have disabled that system. You don't need to keep yelling at me.
Wish you could hide that "Visit your dealer" message.
I have a headlight problem now dealer is trying to sort it out..
It comes on as soon as I use the headlights and doesn't go away until I leave the car off for a while.
Makes it hard to see important info like my speed on the dash!
Old Oct 3, 2025 | 08:02 PM
Thomaslexus
Default Help Again!!!
I don’t know what to do. It seems as though I been thrown in a hole that I can’t crawl out of! It started out as a check engine light and a message that said ecm throttle body or transmission control. I ignored them for my stress levels. I was 2 hours from home at a doctor’s appointment. While on the way home I stopped to fill up. I noticed my car kept sputtering as I filled the tank. When I got on the highway the car completely cut off while driving in the middle of the road! I noticed a message that said battery charging system malfunction or overheated. I kept hitting the start button and finally the car started and I took off. I made it home safely. The next few days I stopped by the service station again. I noticed air coming from my gas cap as I screwed the cap off the filler neck ! After I filled up the car would not start. Finally while pressing the start button, on the seventh try it finally started. I got home and screwed the cap off again. It was pressurized. After googling a few things, I went to NAPA and ordered a purge valve and purchased a fuel cap from the Toyota Dealer along with an oil change. The car seemed revived until we drove it several hours and finally coming to a stop as the rpm’s dropped around first gear, the car did a little sputter, like a big hiccup! So we visited the gas station again. No pressure on the gas cap! As I was fueling, the car started sputtering. It didn’t cut off but I helped it by giving it rpm’s . I don’t know if by not having the check engine light turned off that its still triggering a malfunction and causing these mishaps I thought the light was going to turn off by itself. I did notice a small crack in a vacuum hose going from the purge valve to the throttle body but not sure if this is the cause. I ordered that hose from Lexus and I have to drive 2hrs to pick it up. What should I do.
Old Oct 4, 2025 | 12:46 AM
ESh's Avatar
ESh
Put some el. tape around that crack and try it.
Can somebody read the codes for you?
Old Oct 4, 2025 | 02:52 AM
Thomaslexus
I tried to get Toyota to do it when I was at the dealer today for an oil change. Of course they wanted to charge me that diagnostic fee etc. and I understand. While there, I stepped to the parts department and purchased a set of windshield wipers and gas cap.
In the morning I will stop by advance auto parts and see if they can scan the check engine light and see what code is causing this and eating at my wallet.
Old Oct 4, 2025 | 04:50 AM
zul8tr's Avatar
zul8tr
What year and model is your ES350?
Terrible what health issue you are dealing with, wishing you a great recovery,
Old Oct 4, 2025 | 05:42 AM
Thomaslexus
2019 es 350
