Oil Change (extraction method?)
Old Mar 31, 2025 | 06:54 AM
Barncobob's Avatar
Barncobob
thats a good deal.
Old Mar 31, 2025 | 06:55 AM
es250fsport's Avatar
es250fsport
I just don't like someone else sitting in my car unless I have to haha
Originally Posted by mikemu30
I pay $80 at my inde shop and they use Penzoil full synthetic 0W20. They'll even rotate the tires for free if I want that. No mess, no getting rid of used oil. I get it - some folks love doing it themselves - no thanks.
Old Mar 31, 2025 | 07:03 AM
edbro's Avatar
edbro
A bit off topic but can the approved oil and filter be purchased at a Toyota dealer for less than at the Lexus dealership? Same for drain plug gasket.
Old Mar 31, 2025 | 07:10 AM
es250fsport
Check the model of your engine. If it matches to a Toyota model (like Camry), it will fit.
You will notice genuine parts will usually have Toyota/Lexus genuine parts for this reason.
Old Mar 31, 2025 | 07:16 AM
bc6152's Avatar
bc6152
Dealers use bulk oil which I call "mystery oil". You can buy name brand full synthetic oil at Walmart for cheap such as Pennzoil, Castrol, Quaker State, and others, and an OEM filter at the Toyota/Lexus dealer if desired. A pack of Dorman washers is about $5.00 at Pep Boys or Auto Zone.
Old Mar 31, 2025 | 07:21 AM
es250fsport
If you give the VIN of your car to Toyota parts, they will find the right part.
Their part department is there to sell parts and make money.
They won't reject you because you have a Lexus
Old Mar 31, 2025 | 07:52 AM
E46CT's Avatar
E46CT
If I still had to do oil changes, extractor would definitely be my way to go. I used to do that on my BMWs back in the day. On that particular engine I was rebuilding one and I did a test with the oil pan out to see how far the tube would go and it goes straight to the bottom. So anyone saying it doesn't get all the oil out is speculating without testing the actual pan. I suppose you can look at a pic of a used oil pan of your engine to see if there's any obstructions preventing the tube from touching the bottom.
At the end of the day you're splitting hairs. it's not a rocket motor so replacing 94% vs 95.2% of the oil is not going to really be a substantial difference in the grand scheme of things, assuming it's even true the extractor picks up less oil.
Also no one is saying you won't replace the filter if you used the extractor method. Of course it would be replaced. Goes without saying.
PS i looked at a pic of the 2.5L oil pan. i dont see any reason why the tube wouldn't reach the bottom. but i haven't tested it so. i suppose all one has to do is drain the oil using the traditional method, then stick a tube down there and see how high the oil stain goes.
Old Mar 31, 2025 | 09:45 AM
mikemu30's Avatar
mikemu30
You still have to get under the car for the filter so what's the point? My neighbor has a VW with the filter on the top so he uses one of those pumps and never has to get under. I watched him one time and it seemed to take forever to extract it all.
Old Mar 31, 2025 | 10:36 AM
Barncobob's Avatar
Barncobob
buy filter at dealership,,Lots of BOGUS filters on internet,,,boxes look identical but the inside of filter is what matters.
Old Mar 31, 2025 | 10:45 AM
E46CT's Avatar
E46CT
less time under the car.
it works better though when you don't have to get under the car. this is why BMW designs (as to the oil filter being on top) is superior.
Old Mar 31, 2025 | 11:23 AM
bc6152's Avatar
bc6152
It would be nice (and easier) if Lexus placed the filter on top of the engine. Alas, it's down below where the oil reservoir drain plug is so if you want to change your oil (and filter) yourself, you're on the ground extractor or not... That is, unless you're Mike's neighbor with a VW...
Old Apr 2, 2025 | 09:11 PM
Wilson2000's Avatar
Wilson2000
I don't understand this post in the least, as I've changed oil traditionally my whole life, and haven't ever had an issue with the standard procedure.
The valves that replace the oil plug are cool, but slow to drain, and someone who was trying to mess with you could drain your oil while you are parked, and you'd risk ruining your engine if you drove it.
The extraction method seems doable, but you risk not getting all the old oil out, so why risk it?
For anyone new to changing your own oil, do it for a few years the traditional way and with experience you will find ways to make it go quick and easy.
Old Apr 3, 2025 | 05:50 AM
bc6152's Avatar
bc6152
I'm with you Wilson. If you don't want to change your oil the correct and established way, get it done professionally and forget about it. There are those of us that enjoy working on our cars and don't mind getting our hands dirty. The plus is that you know it's done right and you're not getting screwed.
Old Apr 3, 2025 | 05:59 AM
es250fsport
100 percent..
You don't know what oil they are using.
What I also find is that everytime I take it in, they over fill the damn thing slighly! I know it shouldn't cause an issue but I am very OCD when it comes to maintenance
Old Apr 3, 2025 | 10:54 AM
mmatheny's Avatar
mmatheny
Originally Posted by alextv
I always go by feel and there is rubber on the washer that collapses and that is why you should replace each time.
Rubber on the oil drain washer? My Tacomas all had a copper washer.
