2024 ES300H Code P11EF
Old Jan 4, 2025 | 06:07 PM
jayplexus's Avatar
jayplexus
2nd gear
Default 2024 ES300H Code P11EF
I have always owned Toyota's and Lexus cars because of their reliability, but I bought a 2024 ES300H Lux a year ago and I am already having issues. A month ago when I took it in to the dealer for the 10K oil change maintenance they found an oil leak on the oil drain pan and had to change the gasket. Recently the car was randomly shaking when driving and/or idle. On New Year's Day the check engine light turned on and I used my scanner to check for the code, which was P11EF. I took it to the dealer the next day and they determined that the fuel injectors need to be replaced. Has anyone else had this same issue or did I jsut get a lemon?
Old Jan 5, 2025 | 12:25 AM
ESh's Avatar
ESh
I don’t think it’s lemon but a fault injector and an oil leak can happen. It is better for them to be replaced now when the car is under warranty
Old Jan 15, 2025 | 11:35 AM
BamaBoy's Avatar
BamaBoy
Make sure you are using a Top Tier Fuel for you car. The TTF is identified at stations that have it. Most major brand gas companies are TTF. You can google which companies and it will show a list and why it's important.
It has the required detergent level recommended by car manufactures, helps keep the injectors, valves and intake clean.
Tonyhurr
Dec 21, 2023 06:44 AM
cognus
RX - 3rd Gen (2010-2015)
Jul 30, 2020 03:47 PM
