Sway bar upgrade
Old Nov 5, 2024 | 06:52 AM
kazhuveri's Avatar
kazhuveri
2nd gear
Default Sway bar upgrade
I upgraded the sway bar on a 2023 Lexus ES300h Base to Progress Technology - 28.5mm Adjustable Solid Rear Sway Bar (62.2191).
The OEM sway bar was 8 lbs. The Progress sway bar was 17 lbs. The thickness was almost the same (28.5mm). The Progress bar came with brackets and polyurethane bushings.
The ride was harsh when I used the polyurethane bushings, so I went back to the OEM rubber bushings.
I used the outer hole on the sway bar, ie., the softer setting.
The car doesn't sway as much as before. Got the sway bar from Nextgen Tuning. Overall, I am happy with the upgrade.
Old Nov 7, 2024 | 09:56 AM
E46CT's Avatar
E46CT
That also means you get less independent wheel travel (harder ride). This is the very last car i'd to this to. in fact, i'd opt for a smaller sway bar and softer shocks in the ES. I want it to be floaty. Also white wall tires.
Old Nov 7, 2024 | 11:38 AM
MAMOSKO's Avatar
MAMOSKO
What did you do with the OEM sway bar?
Old Nov 7, 2024 | 01:51 PM
kazhuveri's Avatar
kazhuveri
2nd gear
It is in my garage, for now.
thirdmotio
Apr 7, 2005 06:14 PM
George Hsieh
Nov 8, 2002 05:12 PM
