2013 ES350 headlight and Check Engine lights indication won'tshow up on startup.
Hello All,
I have just got my new lexus, it's a 2013 ES350. I have found that the Check Engine light and main headlight indication is not appearing on the main screen, after switching on.
All indications should light up upon startup, to ensure the lamps are not blown out, right?
Has anyone faced similar issue with theirs? Is there a blown out fuse or the connections to these two indications have been cut off?
Also, when I switch on the head light, they work fine but I don't see an indication on the main screen but I do see the indication for other lights.
Thank you in advance for the help.
is250girls
04-14-15 01:00 PM
