ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
2017 es350 door lock and power window switch
Old 11-07-17, 06:38 PM
Kathyses
Kathyses's Avatar
Default 2017 es350 door lock and power window switch
The door lock and power window switch lighting in my wife's 2016 ES350 is very dim and extremely hard to see the buttons after dark. Has anyone changed or upgraded the bulb to LED?
Old 11-09-17, 11:33 AM
RKF350
RKF350's Avatar
You can dim/brighten with the dash panel control. Have you tried that?
Old 11-09-17, 07:59 PM
Kathyses
Kathyses's Avatar
Thanks, I checked the dash adjustments first. Stopped at the dealer today and they said it appears to be working properly. They said the switch has a built in bulb, therefore you would have to change the switch. I asked if anyone else complained about this and they said no. I just can't imagine that this is true.
Old 11-10-17, 08:10 AM
jollick
jollick's Avatar
I would go to the dealer after dark and have them show you one in the lot for comparison.
Kathyses (11-10-17)
Old 11-10-17, 08:25 AM
Kathyses
Kathyses's Avatar
That's a great idea, I was there yesterday but it was only 3:30 and not dark enough.
Thanks again
Old 11-10-17, 08:57 AM
bc6152
bc6152's Avatar
Received 1,238 Likes on 870 Posts
After reading your answer to Kathyses to use the dash adjustment to increase the brightness, I went out and tried to adjust my switch lights. On my 2013 making the dash instrument lights dimmer or brighter does not change the illumination level of the door switches.
Old 11-10-17, 09:00 AM
Kathyses
Kathyses's Avatar
Do you find your lights much darker than your other cars?
Old 11-10-17, 09:55 AM
bc6152
bc6152's Avatar
I would agree that I would like them to be a little brighter. My Corvette and the boss's Honda are, indeed, easier to see... I have no plans to alter or replace the switches, have to depend on touch to select the right one...
ogaustin
06-28-16 10:19 PM
MrlexEd88
03-07-16 06:00 PM
babaliont
02-18-14 11:10 AM
Woozy
04-07-11 08:51 AM
agood1
09-02-07 12:07 PM
Quick Reply: 2017 es350 door lock and power window switch
