Will BC coilovers for ES300H fit ES350 (non hybrid)???
Wondering if anybody had installed the BC coilovers made for ES300H on ES350 (non-hybrid) model yet?
I did compare both ES300H and ES350 model's shocks/springs parts#, found out that they have the exact same part# for the front shocks/springs BUT different part# for the REAR (mostly likely due to the hybrid is heavy at the rear--Battery).
And also got the an answer from BC, a sale rep said it's mostly likely will fit. Can't believe that is their best answer. I'm not going to spend over $1k along with labour to just test fit their kit.
They had already spent the time and R&D cost to develop the Coils for Hybrid model and they can't even spend a little time to test the coils on ES350 which the more popular model and probably the same chassis? They can even just buy the ES350 REAR shocks/springs to compare with their ES300H Rear coils if they are too lazy to do the test fit.
Thanks
Thanks
Coilovers for Camry 2012 and up work on the ES 350. However due to the extra weight of the car upgrade your springs rate to something stiffer or expect to bottom out even on full stiff dampers.
BC coilover
Thanks
Thanks
yes, you can install BC coilover on es300h.
BLexodus (12-10-20)
FordGT08
Suspension and Brakes
21
05-01-13 01:44 PM
