ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Break Squeal in reverse
Old 02-26-13, 06:08 PM
A320pilot
A320pilot's Avatar
Default Break Squeal in reverse
Does anybody have a break squeal when its cold out while depressing the brakes in reverse?
Brought my car to dealer 1 on the 31 of Jan. and they started a TAS CASE,
almost 4 weeks later, I brought my car to dealer 2 on Feb. 25 and they started a TAS CASE.
Both dealers are looking to Lexus Techs for an answer.
Anybody experience this with a solution or remedy?
Old 02-26-13, 07:59 PM
amphipri0n
amphipri0n's Avatar
Have noticed this as well, esp. if the car has not been used for a couple of days ... Goes away pretty quickly though
Old 02-26-13, 08:32 PM
newone88
newone88's Avatar
This morning it was very cold in San Francisco and heard it and thought do I need to change the breaks
already...(-:
But it went away fast
Old 02-26-13, 10:12 PM
Arty101
Arty101's Avatar
Might be surface rust on the rotors that wears away with a little braking.
Old 02-26-13, 10:20 PM
unowned
unowned's Avatar
certain brake pads when cold will squeal a bit. Check again when they got a bit of heat in them
Old 02-27-13, 03:25 AM
ElliotB
ElliotB's Avatar
I had this issue with my '11 ES350. They changed some kind of clip on the rear brakes and it resolved the problem.
Old 02-27-13, 06:47 AM
CurryPot
CurryPot's Avatar
Had this "issue" on my 2005 Prius and 2010 HS250h when left in the drive way during damp conditions. It happens occasionally on my ES300h but it is more of a rubbing sound that goes away after around 50 yds. I put it down to the lack of use of the real brakes, so the rotars get a little rusty.
Old 02-27-13, 11:05 AM
mrBillFL
mrBillFL's Avatar
is/was the E-brake used prior to putting car in reverse?
ie., sticking e-brake? -normally ebrakes are drums, and they can stick...
Old 02-27-13, 11:54 AM
JerryKK
JerryKK's Avatar
Yep, I have the squealing in reverse - on my ES300h. Keep my car in the garage and every time I reverse the car out of the garage I hear the screeching noise. It's on my list to have it checked out when I bring it in for the 6 month checkup.
Old 02-27-13, 12:02 PM
jollick
jollick's Avatar
I always back into my garage so I have not noticed it, however, at work I back out of my spot, we have had lots of rain here in the last few weeks and I have not noticed any squeal in reverse.
drgrant
01-05-20 02:36 PM
hhenry510
05-02-17 08:32 PM
coolcow
ES - 5th Gen (2007-2012)
13
07-02-08 03:44 AM
S54toIS350
Suspension and Brakes
12-14-07 06:20 PM
Juan C. Cos
09-08-01 09:47 PM
Quick Reply: Break Squeal in reverse
