My clock won't keep time
Old Jan 9, 2023 | 01:21 AM
Aaron9000's Avatar
Aaron9000
3rd Gear
Default My clock won't keep time
Car is a 2014 ES350 I think its running fast for some reason. when I reset the time the hands move evenly like they should. I accessed the time function thru the screen and it was correct, the clock was way off though. Also it said resetting the infotainment clock does not effect the dash clock.
Any thoughts??
Any solutions???
Old Feb 9, 2023 | 07:48 PM
antman747's Avatar
antman747
2nd gear
Mine was this way and I just kept adjusting it and it works now. YMMV
Old Feb 10, 2023 | 02:49 PM
frankymenz's Avatar
frankymenz
I removed my clock from the dash, disassembled it and glued the magnet and white gear together, there is a thread with pictures and good how to do, it may have been in the GS350 section but a search should find it, if you search my posts it should come up as well since I thanked and commented on the fix. The clocks are around 250 bucks, the repair is not that hard.
Old Feb 12, 2023 | 10:50 PM
Aaron9000's Avatar
Aaron9000
3rd Gear
Thanks for the tips!!! Is there a way to get the nav/radio screen to display the time on all menus?? That thing is always right if I go to "system time" thru a bunch of menus.
Old Feb 13, 2023 | 02:36 PM
frankymenz's Avatar
frankymenz
I don’t have NAV so I can’t say for sure, although I seem to recall several comments saying the dash clock and clock in the nav are independent, I’m not sure if it’s possible to always have the time show on your screen? The dash clock fix was pretty easy and worth the hour or so it will take you.
Old Apr 23, 2025 | 05:07 AM
samsonn25's Avatar
samsonn25
My mechanic has this problem on his 18 ES300h
Old Apr 23, 2025 | 07:00 AM
frankymenz's Avatar
frankymenz
Show your mechanic this thread, I repaired a co-workers GS350 about a year ago, his clock had a few differences from mine, an extra board and electrical plug but same fix. I’m not positive for 2018, if it’s the same basic Lexus clock, should be the same fix, mine kept running too fast.
isflexus
IS F (2008-2014)
12
Nov 17, 2014 03:50 PM
mydawgz
Jul 31, 2012 01:08 AM
firstimer
Aug 26, 2010 05:44 PM
hashs99
Apr 9, 2006 05:26 PM
