Replacing Shocks/struts/springs for comfort
Hi all,
have any of you replaced shocks/struts/springs at car's "middle age" for comfort reasons? at 68,000 miles, my ES300h is starting to feel rougher going over pavement holes and irregularities, and at times starting to feel a bit too bouncy on a road with undulations. I'm wondering about replacing suspension just to get back to new car level of comfort (I have no desire to lower the car or anything like that). If so, is it best to ask for OEM parts, or are there options that will further improve ride comfort? How much does cost run, including parts and labor? It seems odd to replace suspension when I haven't even had to replace brake pads yet! However will need to replace brakes soon, so wondering if I should get suspension done at the same time thanks! |
This is from the 5th gen forum, but it kind of goes into some info that you might find useful on the topic. Started the thread because the dealer used aftermarket parts and the right was so not like a Lexus after: https://www.clublexus.com/forums/es-...-the-same.html
Originally Posted by bostonsnow
(Post 11201815)
Hi all,
have any of you replaced shocks/struts/springs at car's "middle age" for comfort reasons? at 68,000 miles, my ES300h is starting to feel rougher going over pavement holes and irregularities, and at times starting to feel a bit too bouncy on a road with undulations. I'm wondering about replacing suspension just to get back to new car level of comfort (I have no desire to lower the car or anything like that). If so, is it best to ask for OEM parts, or are there options that will further improve ride comfort? How much does cost run, including parts and labor? It seems odd to replace suspension when I haven't even had to replace brake pads yet! However will need to replace brakes soon, so wondering if I should get suspension done at the same time thanks! Also what Tires do you have? Tires affect the ride alot? 68k does not seem to be a problem for most with shocks/struts/springs on the 6th Gen ES. |
Your tire pressure could be too high
right, 68,000 on 2016 ES300h
I have Michelin MXV4's. when it was new I found the ride firm so have kept pressures low all along based on all the forum posts, I keep around 30psi cold. that softened the firmness of ride, but now its more so that going over bumps seems more jolt invoking, and on undulating roads a bit more bouncy/floaty. |
It is surprising that with only 68K mile a 2016 Lexus has a worn suspension. You may want to take it to a dealer to have it checked out. I keep pressure at 30psi too on Pirellis which are equivalent to the MXV4s. Ties would be the first thing to check. If you do decide to change suspension part I would suggest you go with OEM if you want the Lexus ride.
Originally Posted by zes
(Post 11206905)
However, while all that was being done, I was given an NX loaner and drove that back home and across the bumpy potholed streets near my house. This 1 year old NX rode worse over those streets than my ES!! So I think the chief problem probably is that my local streets are getting worse!!! So I wont do anything for now, will keep driving . For my last ES, I think it was at around 120,000 miles when it started to get too bouncy and swaying and not tackle bumps well (and then I traded it in rather than change suspension) |
Yea I've had a loaner NX and the ride is a lot stiffer than the 6th and 7th gen ES. Probably every gen ES.
Potholes
(Post 11217445)
ok, I went for service and had the dealership look at it. They said that there is nothing wrong per se with the suspension. They said to not expect a totally new car level of ride at this age, that it can slowly deteriorate, but there is nothing broken per se. He said that there is no need to replace it, however it can be done for comfort if I desire
(Post 11217445)
| All times are GMT -7. The time now is 07:54 AM. |
