Cleaning Throttle Boby
Good day,
I’ve cleaned the throttle body and MAF sensor on my Ford truck recently. Watched a couple of YouTube’s to get the gist of it, not that hard. With that said I was wanting to do the same on my 2014 Lexus ES 350 with 89,000 miles. However I am not finding hardly any videos on the 6th Gen. throttle body cleaning procedure. So my question is are there any pitfalls or “I gotchas” that I should be aware of? I am new to this forum and will continue to search for perhaps a guide. Appreciate your time, Regards, Kevin S. |
kbstall, If you use a top tier gasoline you don't need to clean the throttle body. The top tier gas has higher detergent additives than the no name brands. It's also recommended in the owners manual! I've been driving for over 50 years and always used Shell gas and I never had to clean carbs or injectors or throttle bodies.
Thw throttle body will be ful of dirt no matter what fuel you use.
Originally Posted by autotech13
(Post 10986501)
Originally Posted by kbstall
(Post 10985888)
Good day,
I’ve cleaned the throttle body and MAF sensor on my Ford truck recently. Watched a couple of YouTube’s to get the gist of it, not that hard. With that said I was wanting to do the same on my 2014 Lexus ES 350 with 89,000 miles. However I am not finding hardly any videos on the 6th Gen. throttle body cleaning procedure. So my question is are there any pitfalls or “I gotchas” that I should be aware of? I am new to this forum and will continue to search for perhaps a guide. Appreciate your time, Regards, Kevin S. I also have had the Toyota Dealer do a upper intake cleaning service. Its a good thing to do. I notice how much cleaner the car runs and idles, after I do it. I also run Chevron Techron Fuel additive every month or two in the Tank. Lots here think you should not do anything to your car but put gas in and change the oil and filter. To answer your question, nothing much different on the ES than most others cars to do this. |
| All times are GMT -7. The time now is 11:53 PM. |
