Subwoofer change
Old Dec 6, 2022 | 02:56 PM
  #46
Sebas350's Avatar
Sebas350
Originally Posted by FamilyGuy
I connected everything and found that bass is definitely better now.
But sub needs enclosure, so I decided to implement it similar to Lincoln Town Car where subwoofer enclosure is mounted under the rear deck.
I tried to make a model and 3d print it. The lowest estimate I got was $600. Hmm... No, thank you. I'll go traditional old school way. The new technology is not ready yet.
did you wire it with the stock speaker wiring?
Old Apr 8, 2025 | 10:28 AM
  #47
BTarallo's Avatar
BTarallo
2nd gear
Default Awesome job!
Final look:
This looks great! Is there any spot you were able to find instructions for removing the back seat?
Also, a few questions on the box enclosure. How much room does the box cover? Does it block you from placing larger items into the hole to the main cabin? Also, what straps did you use? Is the enclosure easy to remove or do you have to open access through the back seats to remove it from the trunk?
305Busa
12
May 14, 2020 06:28 AM
geekhou05
Jun 9, 2012 12:55 PM
unit74
Apr 15, 2007 11:54 PM
evolve
Nov 6, 2006 02:49 PM
Dsmart
Mar 26, 2005 10:34 PM
