30K Service Question
Yes. Brake fluid is hydrophilic, i.e. it likes water. Water dissolves in brake fluid and it can cause corrosion in the brake system. It is a good idea to change it.
It is also a good idea to change coolant periodically. I remember when I was a child my dad used to joke that changing coolant makes as much sense as changing air in the tires. Now I understand that coolant dissolves oxygen over time and that makes it corrosive.
Yes, I would. I actually missed it when my ES hit 30,000 miles... when I realized I missed it I had it done when I changed oil at 35 K miles... actually a little surprised that the service writer at the dealership didn't mention it.
Get it done. It is about $120. I get all my maintenance done a la carte. The 30,000 mile maintenance is brake fluid changed, oil and filter changed tire rotation and cabin and air filters replaced. The rest is a bunch of inspection that is not needed IMO. This service will be about $550. Getting each service done a la carte would be around $220 plus the filters. The filters are about $20 each and takes five minutes to replace. Total $260.
