ABS/VSC lights on?
Old Jun 2, 2021 | 04:08 PM
radiologym's Avatar
radiologym
Default ABS/VSC lights on?
Hello,
After my 2007 ES350 was not driven for 2 weeks, multiple lights are coming on intermittently. Please disregard tire pressure as that was before.
Is it wheel speed sensor since it is intermittent or rust since car was not drivem?
I am taking car to Costco soon to replace tires, will they be able to diagnose it?
Old Jun 2, 2021 | 06:46 PM
jagtoes's Avatar
jagtoes
Originally Posted by radiologym
Hello,
Check your battery . sounds like it is going bad. What is the Voltage. It should be 12.6 V at the battery with the engine off.
Old Jun 5, 2021 | 08:49 AM
Clutchless's Avatar
Clutchless
What he said. It is most likely random lights triggered by low voltage from a weak battery. Just get a new battery from Costco.
Old Jun 6, 2021 | 06:25 PM
radiologym's Avatar
radiologym
I wonder if I need to unplug small cigarette lighter charger when I don't use car for prolonged periods. Is there a one in 2007 ES that stays powered when engine is off?
Old Jun 8, 2021 | 05:04 PM
Clutchless's Avatar
Clutchless
The lighter outlet does not have power when the car is off.
If you want to use a solar battery maintainer you need to connect it to the battery. Then run the wires from out of the hood into the driver or passenger door and place the solar panel on your dash. I have one and have used it on several cars this way.
However you should first replace your battery.
Old Jun 8, 2021 | 06:27 PM
radiologym's Avatar
radiologym
Of course, will do. Is it as easy as dropping new battery in and reconnecting it?
Old Jun 9, 2021 | 04:38 AM
Clutchless's Avatar
Clutchless
Easier. 2 small spring clamps (like on jumper cables) attach to your battery posts. A small cable connects to the solar panel. You can connect or disconnect the whole thing in under a minute.
Many of them have a quick connection in the wire between the battery clamps and the solar panel. So you can leave one half connected to the battery if you want.
You do have to open the hood and stash the wire somewhere.
I find it just as easy to unplug the whole thing when driving so I don't have to worry about it moving around under the hood or getting lost. I usually run the wire out the rear of the hood, along the panel gap to the door and inside the car to the dash.
Amazon has many available for under $40.
Old Jul 8, 2021 | 09:00 PM
radiologym's Avatar
radiologym
Went to replace battery but it was good. I still have those lights come and go, possibly triggered by road bumps. Loose connection? Lights started first after I asked mechanic to see if he can fix very slow timing cover oil leak, he decided to try composite/glue over the leak area. That did not work but now I wonder if the issue is related. Would OBD scanner be able to provide more info?
Old Aug 30, 2021 | 05:21 PM
radiologym's Avatar
radiologym
0Changed the battery, for a day no lights on. Today they came back.
swat1727
Jan 15, 2019 02:53 AM
ard4484
Oct 23, 2018 09:49 PM
don460
Nov 24, 2016 08:06 PM
alwaleedi
Jun 25, 2014 08:04 AM
Baby ///M3
Aug 11, 2011 04:59 PM
