power steering stop leak
Old Mar 27, 2020 | 10:22 AM
JimD's Avatar
JimD
10th Gear
Default power steering stop leak
Hi, first post. I have a 2008 ES-350 with 175,000 miles on it. I am leaking power steering fluid and was told that it is the pump that is leaking. I was ready to put Lucas Power Steering Stop Leak in it but then I looked at this forum and found out that the PS uses Dex. III ATF. Should I still use a PS stop leak fluid or something else? The Lucas Trans. fluid says it stops slipping but doesn't seem to mention leaks. Has anyone had any luck with any particular product stopping a PS leak? Thanks.
Old Mar 27, 2020 | 06:33 PM
ESh's Avatar
ESh
It uses Dex 2 or Dex 3. You can use Lucas stop leak. You can buy a gasket set for around $30 and you can rebuild the pump or you can buy a used pump for $50-60.
Old Mar 28, 2020 | 06:34 AM
JimD's Avatar
JimD
10th Gear
Originally Posted by LjeksesES
It uses Dex 2 or Dex 3. You can use Lucas stop leak. You van buy a gasket set for around $30 and you van rebuild the pump or you can buy a used pump for $50-60.
Hi
Do you use the Lucas Power Steering Stop Leak or the Lucas Transmission treatment? Thanks for your help.
Old Mar 28, 2020 | 06:52 AM
ESh's Avatar
ESh
Lucas power steering.
Old Mar 30, 2020 | 10:16 AM
Riick's Avatar
Riick
Snake oil usually works -somewhat- for a limited time.
Best to figure it's a temporary fix, & you're going to have to rebuild or replace the pump.
Old Apr 19, 2021 | 07:55 AM
TD8834547's Avatar
TD8834547
Hey everyone, when I brought my car in for service it seems that the rack end seal that appears to be leaking, not the pump. Would this Lucas Oil Power Steering Stop leak be effective in stopping the leak? Mechanic suggested I replace the whole rack for $3K which seems high.
Old Apr 19, 2021 | 09:34 AM
SunglassesGuy's Avatar
SunglassesGuy
racks run 200-500 bucks. thats 2500 for labor. there are some pretty tight spaces in there to get at it, so that could be right. if it was me, and it was not leaking bad, like a small drip and have to refill twice a year or something, I'd try the stop leak first.
this is one of those jobs, that while your in there, you may as well replace inner and outer tie-rods and steering boots = that labor has to be done anyway.
Old Apr 19, 2021 | 10:27 AM
TD8834547's Avatar
TD8834547
Thanks Jim, will try the Lucas Oil Stop leak and report back .
Old Apr 19, 2021 | 11:41 AM
crazyponch's Avatar
crazyponch
Sounds similar to the dribble on a 08 ES350 PS Hose clamp at pump an 'O' ring.. I have replaced the 'O' ring and added a Hose Clamp but no cigar. Unable to see a leak anywhere else. WTF. Next will try Stop Leak....
Old Apr 19, 2021 | 12:32 PM
TD8834547's Avatar
TD8834547
I didn't see any leakage under the car after It had been sitting for 2 days, I assume the leak stops when the system isn't under pressure? the ps reservoir was just above "Min" so I'll fill it up with the Lucas Oil product and see if that resolves the leaks for good.
Old Apr 21, 2021 | 08:58 AM
overclock's Avatar
overclock
I replaced the power steering pump back in October. The bolt on top was on there really tight. After I replaced the pump the return hose started leaking. It took me 8 hours to replace that hose. Seemed like every nut was in a place I could only get about 1/16 of a turn. Make sure it's not the hose leaking instead of the rack. The hose is notorious for failing.
Old Apr 21, 2021 | 09:07 AM
TD8834547's Avatar
TD8834547
so far no leaks seen when I checked yesterday.
Old Sep 9, 2021 | 03:55 PM
Ddk912's Avatar
Ddk912
Ive Been sorting out a seriously undermaintained 2000 gs400 I picked up a couple f months ago. The only thing left needing obvious attention is ps fluid leak. Rack is aftermarket, so obviously this has been an issue before. I’ve had the car a couple months and put 2000 miles on and had to add fluid once. A couple ounces of dexron fluid with stop leak. It’s going to be a “condo car” sitting for long periods of time, so my thoughts are just to keep the fluid topped up and leave it be. Is it really $3k for a rack replacement? How much just for the pump? I’m in Minnesota and have to get it to Florida and am concerned about blowing a seal completely wher it wouldn’t hold fluid.
Old Sep 9, 2021 | 04:12 PM
Ddk912's Avatar
Ddk912
How hard is it to replace the pump?
Old Sep 10, 2021 | 09:49 AM
iceblast's Avatar
iceblast
Any tips on performing this work? Looking to flush the power sterring fluid but don't want to cause any additional, expensive problems.
