ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Head Light Issue (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/912803-head-light-issue.html)
fbeigh Feb 27, 2019 04:25 PM
Head Light Issue
My driver's side head lamp has been dying after driving about ten minutes. I turn the lights off/on, and the head lamp in question turns on again for ten minutes and then dies. Occasionally, the light will flicker as well. Is this simply an indicator that it is time to change the light, or is there a bigger problem surrounding the issue. I sincerely appreciate any input or guidance.
jagtoes Feb 27, 2019 05:29 PM
Put the passenger side bulb in the drivers side and the drivers side in the passenger side. See if the problem comes up again and whether it is the same bulb . Replace as required but if 1 bulb is bad replace both of them. Do you have halogen or HID bulbs.
fbeigh Feb 27, 2019 05:50 PM
Thank you for the guidance. I have the HID lighting system
igzy Feb 27, 2019 07:18 PM
That's a sign of the HID bulb dying... Mine did the same thing, and eventually didn't come on at all...
fbeigh Feb 27, 2019 07:21 PM
Thank you for the replies! I'm relieved to learn it is likely a head light replacement rather than a bigger undeying issue.
ESh Feb 28, 2019 04:51 AM
^this
If the problem stays right then it is the balast.
cl206 Feb 28, 2019 09:19 AM
That's what happened to me. See the link below:
https://www.clublexus.com/forums/es-...ght-issue.html
