2007 p0500
Old Apr 18, 2018 | 09:21 PM
scotthinsd's Avatar
scotthinsd
Default 2007 p0500
2007 es 350 had a P0500 code. reset with obd and now fuel mileage is down and seems to be shifting weird
Old Apr 18, 2018 | 09:33 PM
Lexmus's Avatar
Lexmus
That is the code for the speed sensor. Is your speedometer working properly? I can imagine the tranny shifting improperly if the computer doesn't know the correct speed of the vehicle.
Old Apr 18, 2018 | 09:35 PM
scotthinsd's Avatar
scotthinsd
The VSC check light did come on and the car did die a few weeks ago. All the dash lights went crazy and the gauges went to zero.
But this time I just erased the codes and it seems to work but shifts weird and gas mileage has gone down.
Old Nov 9, 2021 | 09:27 AM
nevernu's Avatar
nevernu
I got P0500 recently on my 07 with engine & vsc light and check vsc display. No problem with speedo or transmission shifting or anything else apparently. I clear the code and it comes back as soon as the vehicle starts moving forward. Trusted mechanic on phone says prob something in the wiring but can't book it for several weeks. Any suggestions?
Old Nov 10, 2021 | 04:26 AM
Clutchless's Avatar
Clutchless
Check your battery. A failing battery with low voltage is often the cause of warning lights & codes as they are very sensitive to voltage.
Old Nov 20, 2021 | 02:36 PM
nevernu's Avatar
nevernu
Finally got around to checking battery; its less than a year old and good readings 12.2V at rest/ drops to 10V cranking/ >14V running.
Old Dec 5, 2021 | 02:20 PM
KievanRus's Avatar
KievanRus
How about an update?
Old Dec 5, 2021 | 02:21 PM
KievanRus's Avatar
KievanRus
Old Dec 5, 2021 | 05:06 PM
nevernu's Avatar
nevernu
as soon as I checked the voltage, the next am it wouldn't start! Boosted it and ran it for a while to charge battery and still ok. No change on the code and the warning lights though, It goes in to my trusted mechanic dec 15...
Old Feb 9, 2022 | 12:14 PM
nevernu's Avatar
nevernu
trusted mech found another code beneath the p0500 indicating the vsc sensor which he replaced. now the p0500 is left w the ck engine light still on; dont have (never had) any speedo or shifting problems. he's now looking at the trany speed sensor ... disconnecting it to see if any change in symptoms/codes. ongoing
Old Mar 21, 2022 | 12:56 PM
nevernu's Avatar
nevernu
a happy update. after checking ecm and cluster panel to no avail, he found corroded wiring in the wiring harness located under the engine fuse compartment. Fixed and everything back to normal! The dedication spent tracking down the cause was impressive. Thank you Japan Auto!
Old Sep 30, 2022 | 04:40 PM
smartynote's Avatar
smartynote
1st Gear
Hi, I have the same problem. My Speedometer works and gear shifting well but I keep getting the P0500 (Vehicle Speed Sensor Malfuction) and I have no idea how to fix this, a little more explanation from you will help me a lot; Thanks
Old Oct 1, 2022 | 11:43 AM
nevernu's Avatar
nevernu
as I said, in my case it was caused by corroded wires in the harness under the engine fuse box. this is what the bill says
LoveMy2007
Jun 4, 2021 07:53 AM
Barryst
RX - 1st Gen (1999-2003)
16
Jan 6, 2021 11:27 AM
follie12
Nov 3, 2017 06:18 PM
mirzarafiq
Sep 13, 2017 12:10 PM
Gocards6
May 6, 2017 04:49 AM
