Water pump replacement parts
trying to replace the water pump on a ES350 2010 exactly what should be replaced? the pump assembly the serpentine belt, should all the pulleys go? is there a timing chain to be replaced? thanks Robert
Don’t worry about the timing chain. I did WP replacement at 70000 and I did the following: WP+gasket Thermostat with all the o-rings Coolant Belt roller bearings alternator pulley The belt was like new so I left it there. |
Grateful
thanks, the roller bearing for the pulleys?,
Yes. I think 6302. |
Originally Posted by LjeksesES
(Post 10112279)
Originally Posted by Anglada
(Post 10112205)
You just need coolant and the water pump. If the engine has over 100K, definitely consider replacing hoses, thermostat, serpentine belt and idler pulleys. You will not be able to replace the tensioner pulley without replacing the whole tensioner assembly. Although I strongly suspect you can replace the bearing in the pulley as I did in my 07 Tacoma. And I'm going to guess you also need the dog bone shape engine mount on top of the engine, if you haven't already replaced it. I've seen a couple good youtube videos on replacing the water pump on ES350's. |
