changing driver door mirror assembly ?
Old Jan 31, 2018 | 05:21 PM
ThumperPup's Avatar
ThumperPup
Default changing driver door mirror assembly ?
Hi could someone tell me or post a How to guid on swapping out the driver door mirror assembly
i know how to remove the door panel so that's not a problem
I guess I'm trying to find out more of what tools I need do i need a deep well socker to get to the bolts and nuts that hold the mirror on
is there more to it than just harving a a regular metric rench set and door panel removal tools?
my mirror does not work side to side only up and down the passanger door mirror works in all directions so my issue im feeling is not a fuse and not a switch problem if anyting its a issue with the mirror mottor or a short in the wiring for the mirror itself.
so im planing on replacing it next month.
Old Feb 1, 2018 | 02:35 AM
ESh's Avatar
ESh
I think the mirror is held by 2 10mm bolts, you remove those two bolts and disconnect the connector.
Old Feb 1, 2018 | 07:35 AM
ThumperPup's Avatar
ThumperPup
ok cool thank you
SonomaZ
Jun 25, 2021 11:55 AM
Apothist
Jul 2, 2018 11:04 PM
maxx430
Oct 20, 2014 01:23 PM
extascer
RX - 1st Gen (1999-2003)
Jun 9, 2010 05:37 PM
