issue with heat
i did check the coolant and the level looked good
i am not a pro mechanic so if it was a little low and hard to tell or if it wasn't all in the bottle
either way
dont be a Sh!!T head
it's hard to tell it looked to be at the proper level.
i guess that you cant always go by what it looks like in the plastic bottle
i appreciate those of you who all helped
now the ones that have to be rude screw off and sit on something lol
It is hard to miss the fluid level when you take the cap off and look into the tank. If the coolant level was as low as the dealer said then there is a bigger problem looming. Low fluid doesn't make the car run cooler. The internet is a wonderful thing so do a little more reading .
It is hard to miss the fluid level when you take the cap off and look into the tank. If the coolant level was as low as the dealer said then there is a bigger problem looming. Low fluid doesn't make the car run cooler. The internet is a wonderful thing so do a little more reading.
Yeah I agree! What a miserable life that you have to treat people in such a demeaning manner. He did check the coolant and isn't this forum for just what he was doing? I hope that guy can find happiness.
Last edited by christopherahrendt1; Jan 13, 2025 at 09:52 PM. Reason: unclear as to what I was responding to
