Afs off
Afs off
Hi, just recently moved in Honolulu and my boss provided me with a service vehicle. It was a Lexus ES350. I was just wondering if the "AFS OFF" always lit up on the dashboard, as well as the tire sensor? Though, we already inflated the tire and used a tire gauge with 32 on each tire but the tire sensor is still litting up.
How do I turn off the tire sensor light and is the "AFS OFF" always lit up, by the way, what's the AFS OFF stands for?
Thanks
Jeff
Thanks
Jeff
Automatic Focusing System is the mechanism that adjusts the headlight up and down with varying loads
and in older Lexi would also turn the lenses left and right (more at low speeds!) to follow the steering input.
You should find a button down by the trunk and gas door buttons to re-enable the system. If it is an older
car the sensor on the rear axle gets rusty (unlikely in Hawaii unless driven on the beach) and the system
will fail and trigger the light.
The Tire Pressure Monitoring system uses sensors built into each wheel's inflator. They have a tiny battery
that ought to last 5 years. What year is the ES? For that matter, what job to you have in Paradise that has
a Lexus as a service vehicle?? Hiring?
TECHSINFRA (09-15-17)
Will check as well for the spare tire which popgun mentioned as well.
Thanks
Jeff
Jeff, that button can be a tad hard to find as it is pointing pretty much straight down. You might have to lay down and look up to find it. I think on the '10 I had it was by my right knee. You'll see it.
avanchieri
10-15-16 03:39 PM
Marexus
01-12-12 06:15 AM
