DIY: Overhead console illumination...
One of the biggest drawbacks of this car is the overhead console without illumination, so I decided to **** the TAKUMI's and to get things straight.
I bought 10 LED-s 3V 300 MC, green, 10 resistors (you can put one resistor to every LED or one resistor for all, I made it with one resistor), clear silicone, solder material... http://s7.postimg.org/5peu4k0mz/wujhe.jpg This is the OC (overhead console): http://s12.postimg.org/e6mskiqsd/Capture.jpg Open the "for glasses" and you'll see this, which has to be opened: http://s7.postimg.org/h8a6mjosb/Capture.jpg Use flat screwdriver to open...: http://s16.postimg.org/jxpk3c22t/Capture.jpg Remove those 2 screws: http://s18.postimg.org/s8q5um1mx/Capture.jpg Pull it down: http://s18.postimg.org/3urvmz4jt/Capture.jpg Slide your finger between the OC and headliner and pull down, hard: http://s16.postimg.org/ckeri47et/Capture.jpg Then do it on another side and you'll end up with this: http://s15.postimg.org/oechwt02z/Capture.jpg Turn it over and take off this plug by pressing the clip: http://s1.postimg.org/g3lgzly4f/Capture.jpg This is the back od the OC, remove those 2 screws: http://s18.postimg.org/c5mvmaevd/Capture.jpg This is the home link ECU, turn it over: http://s7.postimg.org/hrxnes9q3/Capture.jpg Unplug this by pulling it: http://s30.postimg.org/71pbj9bmp/Capture.jpg Pull the microphone: http://s9.postimg.org/h19doc5m7/Capture.jpg |
Disconnect the cable on both sides, press the clip and pull:
http://s11.postimg.org/u1evnikzn/Capture.jpg Just pull: http://s3.postimg.org/jc7rdgb9v/Capture.jpg Remove all the bolts, take the cover off and you'll end up with this: http://s29.postimg.org/js78qej9z/Capture.jpg This is the motherboard of the home link buttons, press those 2 clips and pull up: http://s2.postimg.org/gp1losu7d/Capture.jpg Turn it right: http://s7.postimg.org/vyml1hzcr/Capture.jpg Then take the whole motheboard off: http://s22.postimg.org/f73f2y3ht/Capture.jpg Button order: http://s17.postimg.org/v0cxg4cwf/Capture.jpg Button number 3, you have to cut this piece of plastic because in that hole you should drill the hole and put the LED: http://s9.postimg.org/6nwfuk1nz/Capture.jpg Drill a 1mm hole from the inside: http://s13.postimg.org/lm5iywfxz/Capture.jpg Drill a 2mm hole from the outside: http://s18.postimg.org/4qfmubgeh/Capture.jpg Do the same with all buttons: http://s29.postimg.org/f72osi61j/Capture.jpg DOOR and ON/OFF buttons already have this circle so just drill it: http://s29.postimg.org/5y53w4mjb/Capture.jpg http://s4.postimg.org/3uk2nlyjx/Capture.jpg Put some clear silicone in all the holes and then go over it with your finger: http://s12.postimg.org/4efzki7fh/Capture.jpg http://s21.postimg.org/ofzwaoyd3/Capture.jpg http://s7.postimg.org/6cj9akksb/Capture.jpg They should look like this: http://s30.postimg.org/rwya8nkm9/Capture.jpg ...and let the silicone dry. Cut it, the cables should pass through it: http://s24.postimg.org/l2dezfh5x/Capture.jpg |
Solder 2 (1mm) cables, they should be long around 20 cm:
http://s28.postimg.org/4wluoq8nh/Capture.jpg And then put some isolation: http://s28.postimg.org/7unew65ot/Capture.jpg Paste it with super glue, the led should be over the hole: http://s9.postimg.org/s25y30p67/Capture.jpg This is how it should look like. I put some black silicone around the isolation but it is not necessary: http://s12.postimg.org/kc1qdxiql/Capture.jpg Find + and - wires, solder them to 2 wires, one will be connected to + and the other one to -: http://s9.postimg.org/800uy4odr/Capture.jpg On the plug, you'll find 2 green wires, the middle one is the positive wire, connect + wire to it: http://s2.postimg.org/pvapklko9/Capture.jpg The negative cable is there too but I was so tired to look for it so I connect it to the negative wire that goes to the sunroof motor, it is a thick white/black wire. This is the result: http://s23.postimg.org/3sp6ivlu3/Capture.jpg http://s1.postimg.org/z5mzah91b/IMG_1033.jpg They look astonishing, but it took me more than 5 hours to do this. I plan to put two more LED-s for read LED buttons. Maybe you can find small 12V LED-s so you don't need any resistor. I had to put one because like I said those LED-s were 3V. I used a battery to test each LED after I finished with soldering. |
thanks for the disassembly instruction. I'm not really interested in the led install cause I dont use those buttons frequently but I'd like to do something with those 6 terrible reading lights. Maybe you can tackle that problem when u do the leds for the read buttons. :)
I will do it.
P.S. Can you post the front right door panel removal pdf? Thanks. |
3 Attachment(s)
here they are, there are also others dealing with door mouldings, door belt but these should do
Thanks so much for another great DYI.
It's a lot of work but the results are definitely worth it - your install looks great! I am definitely doing this. I plan on only doing the Homelink buttons and the 2 reading lights. I don't use the "Door"/"On off" buttons all that frequently. I was thinking of using green LEDs for the Homelink buttons, and maybe white ones for the reading buttons. Not too sure yet. I ordered both 1.8 mm and 3 mm LEDs in both colours. So the holes that you drilled were 2mm, not 3mm to match your LEDs? |
Originally Posted by nevernu
(Post 8870506)
Thank you. Is that the only way I can get to the front speakers? |
Originally Posted by GCL
(Post 8870522)
(Post 8870506)
https://www.clublexus.com/forums/es3...ld-thread.html |
Thank you. You guys rock.
(Post 8870292)
Ljekses, THANKS for bringing this one back to life! The other gap method seemed so promising, but without the pictures, it was hard to tell. Looks GREAT!
Originally Posted by LjeksesES
(Post 8870737)
Thank you.
Is that the only way I can get to the front speakers? https://www.clublexus.com/forums/es3...-2007-a-3.html look at posts 34 and 36. |
Thank you. Done.
| All times are GMT -7. The time now is 09:36 AM. |
