Spark Plugs
You have a Lexus. Plugs only need to be change about every 1000,000. That's probably about 8 years. Don't try and save $20-$30 on plugs. If you're going to do it yourself, go to autozone or similar and buy good plugs. Get some NGK iridium plugs. A set of 6 will cost about $50. Don't go cheap. Go for good. You shouldn't need a coil.
There's little to no difference in the brand of denzo or ngk. They might even be built by the same factory. There is however a difference between iridium, platinum, and copper. You definitely NEED iridium.
Were you having problems with your car? There no reason to replace plugs so soon. Factory change is at 120,000 miles. 100,000 is understandable. Half the miles is just a waste of money and time. Unless there was a problem or you like to tinker and then the cost can be written as entertainment or enjoyment. If there weren't any existing problems, you won't notice any improvement.
Interesting conversion. I never really considered that. I buy a lot of propane in bulk for work. Generators. But here, propane costs the same as gasoline. So for me, the retro would never pay itself back. Unless lpg can double the mpg. That I don't know. Anyway, good luck with your project.
