Amplifier Remote Wire Locations?
Old Jul 8, 2014 | 11:20 AM
MekDiesel's Avatar
MekDiesel
Default Amplifier Remote Wire Locations?
For everyone that has hooked up aftermarket amplifiers to the stock system, what source did you tap into for the remote wire? I know many people have tapped into the fuse box, others the cigarette lighter wire, and some people have even found wires in the trunk to tap into. I'm curious as to what route people took and why, because I'm looking to move away from the remote turn-on feature of the LC2i.
Old Jul 8, 2014 | 03:07 PM
mlacomb's Avatar
mlacomb
I used a wire that controls power on to the amp in the trunk location. I used pinouts from a schematic for the amp wiring layout; if I can find it again in my documents I'll post it. The only thing I had to run from the front of the car was the 4ga wire for my sub amp and LC2i.
Old Jul 8, 2014 | 07:33 PM
RTSM's Avatar
RTSM
I removed the cigarette lighter and installed a switch using the cigarette lighter power. Works great, no noise, well conceal to keep the stock look easy to access and simple to remove if I ever sell. See the attached. Btw, I'm using the Lc2i and a Rockford fosgate amp with dual JL's. At first I didn't want the switch but I'm glad I installed it, I'm also glad I purchased the JL woofer grills with all of the kids gear being thrown into the trunk. Take a look at the attached pics (sorry for the crappy photos).
Attached Thumbnails Amplifier Remote Wire Locations?-img_0029.jpg   Amplifier Remote Wire Locations?-20140708_191832.jpg
Old Jul 8, 2014 | 08:33 PM
MekDiesel's Avatar
MekDiesel
This schematic?
Old Jul 8, 2014 | 08:36 PM
MekDiesel's Avatar
MekDiesel
Wow. I have to say I'm super jealous of your install - that is CLEAN! And also WAY above my skill level...LOL
Old Jul 9, 2014 | 04:55 AM
mlacomb's Avatar
mlacomb
Looks like pin 12 of the connector on the first page (going into Stereo Amplifier) goes HOT with ACC. I'll pull apart my trunk sometime when cleaning it to see what I tapped... I know I didn't write it down, but I did use a multimeter to confirm. I'm also fairly positive that even if the stereo is off, the amp is still hot while the car is on (bluetooth phone calls use the amp as well) but I'll confirm that too.
Old Jul 9, 2014 | 06:56 AM
MekDiesel's Avatar
MekDiesel
Nice! Did you have to unmount the amp to get to the wire?
Old Jul 9, 2014 | 07:26 AM
SICK350's Avatar
SICK350
I'm loving the cigarette lighter switch idea, I might have to borrow this idea for LEDs.
Old Jul 9, 2014 | 11:07 AM
mlacomb's Avatar
mlacomb
Nope; used a vampire tap on that wire + the 4 front speaker outs.... been solid ever since.
Old Jul 9, 2014 | 01:51 PM
MekDiesel's Avatar
MekDiesel
Hmmmm... I've attached a pic of my vantage point of my amp in the trunk. I tapped into the visible speaker wires easily using that wiring diagram, but have no clue how to get access to the wires on the front of the amp without unmounting it.
Old Jul 11, 2014 | 06:12 PM
mlacomb's Avatar
mlacomb
One of the wires that plug in there is hot when car is on, not when not. I'll look sometime this weekend. I didn't have to unmount the amp, I did remove the plugs that were necessary to vampire tap....
Old Jul 15, 2014 | 11:12 AM
MekDiesel's Avatar
MekDiesel
Did you get a chance to look?
Old Jul 16, 2014 | 04:59 AM
mlacomb's Avatar
mlacomb
Sorry, I didn't - I'll make a note to dig Sunday.. my car needs some TLC anyways.
Old Jul 20, 2014 | 04:59 PM
mlacomb's Avatar
mlacomb
Hmmm. My wires look slightly different...? Mine is non-nav non-Levinson... I vampire tapped the gray wire as shown from the third connector from the top... Gray wire is right beside a blue wire. It's pretty thin.
Attached Thumbnails Amplifier Remote Wire Locations?-img_20140720_153604.jpg   Amplifier Remote Wire Locations?-img_20140720_153618.jpg
Old Jul 20, 2014 | 05:04 PM
mlacomb's Avatar
mlacomb
As you can see, the connections unplug with relative ease. To tap, I peeled back the factory double stick sheath and tapped and re-wrapped. Not the cleanest looking thing in the world, but all wires are still protected - and I can get this back to stock if I ever need.
