ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Front Speaker Installation
Old 06-21-13, 07:09 AM
tscalesy
tscalesy's Avatar
Default Front Speaker Installation
PLEASE HELP!! I just purchased JBL GTO938 Front Speakers and want to install them in my 2007 ES350 myself. Would extra wiring do I need to purchase? Also, do I have to take off the entire door, or is there a way to pop off the speaker guard? I am obviously brand new to this, but figured I would take the DIY approach. Any links to easy door removal?
Old 06-21-13, 09:14 AM
jcat_350
jcat_350's Avatar
Do not do this yourself. You're not experienced enough to get it right.
To install the aftermarket speaker, you'll need the appropriate adapter harness. To get the old one out and the new one in, you have to remove the entire door panel. This is NOT a job for a novice and it's trickier to get the panel back on than to get it off, and you may get yourself stuck in a bad spot trying to do so.
Old 06-21-13, 12:24 PM
Robert_J
Robert_J's Avatar
Welcome to the forum. The search feature is your friend. Here's my thread on the audio system upgrade I did on my '07. And I did not completely remove my door panels.
https://www.clublexus.com/forums/es3...-a-2007-a.html
Old 06-27-13, 10:14 AM
tscalesy
tscalesy's Avatar
Thanks, Robert! Still a rookie at this thing. If you don't mind me asking, was this a pretty simple process? Again, i have never done this before, but feel confident I can figure it out. I read your post and you made it look pretty easy. Looks like I really only need a wire harness and I should be all set.
Old 06-27-13, 12:25 PM
Robert_J
Robert_J's Avatar
It was really tight to work on because I have meat clubs for hands (XL glove size and those are tight). As I wrote, the first one took longer than the 2nd.
If I ever did it again, I would drill a tiny hole through the side of the adapter and run the 2 speaker wires through a tiny hole on the side. You can see in https://www.clublexus.com/forums/6675551-post37.html where the factory plug is.
You may need a 6x9 adapter to give you enough clearance from the window.
orionshoot
05-31-18 01:00 PM
zachpm
NX - 1st Gen (2015-2021)
04-18-17 03:28 PM
Lexample
04-04-15 09:40 AM
BigghookUp
11-11-03 02:01 AM
Shinchan
10-15-01 09:25 AM
Quick Reply: Front Speaker Installation
