ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Old 12-16-14, 11:51 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
Print Wikipost
Brake/rotor change ES350 2007
Old 11-30-12, 09:22 AM
tractng
tractng's Avatar
Default Brake/rotor change ES350 2007
Looking to buy pads and rotors for wife's car. Any decent affordable sets you guys can recommend? Any DIY? Do I need some other parts besides those two? No sensor piece like other cars?
Also, is bleeding the brake lines require?
Thanks so much.
tractng
Old 11-30-12, 02:27 PM
garsarno
garsarno's Avatar
My garage guy bought Lexus pads and Toyota Camry rotors for our previous 2007. Worked great. There was a rebuild type kit he got from Toyota too.
Old 11-30-12, 07:58 PM
oldgrump
oldgrump's Avatar
Are you having issues, or are you going by the pad thickness remaining? Fronts only or rears as well? If you are not having issues like brake judder (vibration under braking) and the rotor thickness is well over the minimum thickness, then I'd reuse the original rotors (deglaze and clean). How many miles on the brakes (if you know)?
Old 12-01-12, 02:23 PM
nhlexus
nhlexus's Avatar
I have always been lucky with akebono. This is usually the OEM brand.
Old 12-04-12, 07:27 PM
cl206
cl206's Avatar
Thanks so much.
tractng
you do not need to bleed brakes if a brake line wasn't detached and it shouldn't be if you're just changing pads and rotors. I would check tirerack.com to get an idea and see how they compare to the OEM in terms of pricing. also, akebono pads are pretty good.
Old 12-05-12, 10:07 AM
CompuMan
CompuMan's Avatar
Default This is what I did (twice)
I bought after market rotors and my buddy installed them. The first set have been on almost two years now with no problems. The second car's rotors have been on for 9 months, and again, no problems.
I suggest that you replace the rotors and pads with an after market set.
Here is what I used for both cars:
The parts are from www.carparts.com:
Parts Ordered
Brake Hardware Kit 2008 Lexus ES350
Centric Brake Hardware Kit ES350
Price: $ 7.67
Qty: 1.00
Part #: CE117.44083
Brake Disc and Pad Kit 2008 Lexus ES350
Powerstop Brake Disc and Pad Kit ES350
Price: $ 193.80
Qty: 1.00
Part #: P15K186
Sub Total: $201.47
Discount: $0.00
Shipping: $18.32
Handling: $4.40
Tax: $0.00
Core: $0.00
Total: $224.19
Old 12-11-12, 01:48 PM
tractng
tractng's Avatar
Thanks guys. Wife's car is at 98k miles? I really don't know how many times she had time replaced. I didn't care to work on her car before.
I will rotate the wheels this weekend and take a peak inside.
CompuMan,
What is that kit CE117.44083 for? Accessories?
Old 12-11-12, 05:30 PM
CompuMan
CompuMan's Avatar
They are misc clips and such like. You can use the originals, but for the money, I chose to buy new so that all of the brake changes were new parts.
Old 01-13-13, 11:56 AM
chuyrobles
chuyrobles's Avatar
I went with Raybestos rotors and pads about 50K ago. They came with the necessary clips, and there was a lot of them!
http://www.amazon.com/Raybestos-980470-Advanced-Technology-Brake/dp/B0015S0JB6/ref=au_pf_ss_2?ie=UTF8&Make=Lexus|75&Model=ES350|2866&Year=2007|2007&carId=002&n=15684181&s=automotive http://www.amazon.com/Raybestos-980470-Advanced-Technology-Brake/dp/B0015S0JB6/ref=au_pf_ss_2?ie=UTF8&Make=Lexus|75&Model=ES350|2866&Year=2007|2007&carId=002&n=15684181&s=automotive
http://www.amazon.com/Raybestos-ATD1222C-Advanced-Technology-Ceramic/dp/B0015S90KW/ref=pd_bxgy_auto_text_y http://www.amazon.com/Raybestos-ATD1222C-Advanced-Technology-Ceramic/dp/B0015S90KW/ref=pd_bxgy_auto_text_y
Old 04-01-13, 05:43 PM
IS350HKS
IS350HKS's Avatar
Anyone know if there are any DIY? thank you all.
Old 04-02-13, 08:38 AM
MadMax96
MadMax96's Avatar
I can't imagine doing brakes on this car is any different from any other typical car. Now the LS I had w/ the 4 piston calipers and pad sensor wire was a little more of a pain - not hard, just different.
If you want something more detailed/specific to this car, you might have better luck searching for a how-to on a Camry. I did a quick search and found this for a 2007 Camry:
I need to do brakes on my ES as well - got the parts and am just waiting for it to be a little warmer when I actually have the free time to do it!
Old 04-22-14, 08:56 PM
iceblast
iceblast's Avatar
To second the OP,
Can anyone recommend good aftermarket pads and rotors for an 07 ES 350? Was there any noticeable loss of smoothness in the ride quality after swapping for aftermarket?
Thanks
Old 04-27-14, 04:12 AM
RXPhil
RXPhil's Avatar
Default Upgrade
Thought I would chime in a let everyone know that 2010+RX350 calipers fit on this chassis. The same calipers are on 2011+ Sienna and 2008-2013 Highlander. Upgrades the rotor from approx.300mm to 330mm or so I forget the exact numbers.
I have a V6 camry and I just did this. Great upgrade!
Old 12-19-15, 05:55 PM
chuyrobles
chuyrobles's Avatar
Took a gamble on brake rotors/pads from a Canadian brake company I've never heard of - MaxBrakes. Paid $81 for Kit # KT039211, that included two slotted/drilled front brake rotors and ceramic pads. Free shipping and no tax. Arrived within a week. Bought through manufacturer's website. Pads had backing shim but no other parts. Paid $13 for AC Delco kit # 18K1892X which includes sliding pin rubber boots and two little rubber rings that go on two of the pins. It was the most complete and affordable kit I could find on Amazon and it didn't disappoint. Unknown country of origin; there are no markings on the boxes; forgot to look closely on the rotors/pads.
Wife's ES350 has 173K miles. These rotors were fourth set installed (previously: OEM, Raybestos Pro Grad, and OEM resurfaced). Pads were also forth set installed (previously OEM, Raybestos Advanced Tech, and AutoZone). After initial test drive, everything is in working order. Rotors look sharp; time will tell as to durability.
Old 01-26-16, 11:02 AM
jkutti2000
jkutti2000's Avatar
THANKS FOR THE TIP.. I USED THEIR SITE AND ORDERED
http://maxbrakes.com/c-1002950-brake...ries-kits.html
THEY SELL ON AMAZON ALSO. BUT THIS WAS CHEAPER AND NO TAX...
I BOT THE KIT U RECOMMCNEDED. SO ONCE IT COMES , WILL GET IT INSTALLED . SO THIS IS A HUGE SAVING..
LEXUS DEALER SAID 330 FOR FRONT. W/O ROTORS.. OEM STUFF. WITH ROTORS. WOULD BE LIKE 500..
Quick Reply: Brake/rotor change ES350 2007
