Help...satellite radio problem
Old Aug 29, 2012 | 01:55 AM
Assassinus's Avatar
Assassinus
Default Help...satellite radio problem
Hi Guys
I am hoping someone can give me some good advise. I recently had the Vais system installed in my 2008 ES 350. Initially it was working fine. But now I am having issues. The problem is at times it plays perfectly clear and with a strong signal but then I start getting interference every so often as is if I had no signal or as if I were going into a parking garage; but I have clear line of sight to open sky. I don't know if its the Vais, the antenna, or a tsb. I called siriusxm and they pinged it twice and said it should be working fine!
Old Aug 29, 2012 | 04:50 AM
RickC5's Avatar
RickC5
Call VAIS tech support. Their contact info is on their web site. I found them to be of great help, while the XM folks really can't help you much.
I also need to add that the communication satellites are way in the southern quadrant of the sky. Even if your car has a clear shot of the sky directly above, a tall building can block the satellite. This even happens to me as I'm driving past the front of our local Walmart or Lowes.
s6 4rings
Oct 23, 2011 01:08 AM
iceburg
Feb 7, 2011 02:05 AM
bobrxlex
Jul 14, 2010 03:30 PM
nahlaterz
Sep 4, 2009 02:07 PM
