Transmission Fluid Change
Old Jun 8, 2016 | 10:51 PM
  #46
chuyrobles's Avatar
chuyrobles
Originally Posted by bhaubold
Does the ES350 have a trans filter that would be changed with the fluid? Is there a mileage interval for this?
Thanks,
Bob
09 ES350
No one really answered the filter question. Yes, the ES350 has an ATF filter; but, no, the owner's manual does not address when to change out the filter. It is a paper element and gets dirty quicker than the mesh types. When I replaced the filter at 155K, it was very dirty. I was glad I replaced it. Removing the ATF pan is tricky as you have to unbolt the front and driverside motor mounts and raise the trany a few inches in order to remove two pan bolts.
https://www.clublexus.com/forums/es-...placement.html
Old Jun 9, 2016 | 03:56 AM
  #47
ESh's Avatar
ESh
Here you can find all the details:
https://www.clublexus.com/forums/es-...with-pics.html
Old Jun 11, 2016 | 09:11 PM
  #48
CookieRoe's Avatar
CookieRoe
ATF filter: Its a strainer, not really a filter. Lots of cars are like this nowadays. Leave it alone. HOWEVER, do drain/exchange/whatever your ATF
LjeksesES: NICE DIY!!!!
Old Jun 12, 2016 | 01:35 AM
  #49
chuyrobles's Avatar
chuyrobles
It's more than a strainer on our 07.
Old Jun 12, 2016 | 06:40 AM
  #50
ESh's Avatar
ESh
It is a filter.
Old Jun 12, 2016 | 06:43 AM
  #51
RandyIS250's Avatar
RandyIS250
awesome answer, yep just change the fluid and leave the filter alone.
Old Jun 12, 2016 | 09:49 PM
  #52
chuyrobles's Avatar
chuyrobles
Old Aug 11, 2016 | 07:42 AM
  #53
B4TM4N's Avatar
B4TM4N
Default Price of Transmission flush at Toyota dealership
We gave my mom's 2008 ES350 to the local Toyota Dealership for transmission flush at 86k miles this past weekend. They charged $219 plus tax after a coupon (Reg price is $239 i believe). I don't know if it is in my head or if I haven't driven my mom's car enough, but this morning while driving it on a 3 mile errand, I saw the RPMs jump between a low gear shift. I'm wondering if this is the "Flare" i read about on the net and I wonder if it happened before the fluid flush. Oh well, we'll see how long the transmission holds up because my mom plans on keeping this car for a very long time. Will post back if anything happens
Old Aug 15, 2016 | 05:16 AM
  #54
MadMark's Avatar
MadMark
After a lot of reading and pondering, I ended up flushing our atf at 75k and replacing the filter. I used valvoline, who at that time was the only manufacturer who made a full synthetic replacement for the world standard fluid. I used the bucket method and I'm glad I did. The old fluid and filter were both very dirty. Car shifts smoother now than it did when we bought it with 50k on the odometer. I'll be flushing it again in another 75k. (I've put 20k on the car since the flush and everything is working great.)
Old Aug 21, 2016 | 07:50 PM
  #55
RookieLEX's Avatar
RookieLEX
Can you provide me the filter part number ? I also plan to flush mines too
Old Aug 22, 2016 | 02:30 AM
  #56
ESh's Avatar
ESh
Gasket: GASKET, AUTOMATIC TRANSAXLE OIL PAN35168-33080
Filter:
STRAINER ASSY, VALVE BODY OIL35330-33050
O ring:90301-27010
Old Aug 22, 2016 | 02:14 PM
  #57
RookieLEX's Avatar
RookieLEX
Filter:
O ring:90301-27010
Does these parts apply to my 2010?
Do I need to replace the Crush washer gaskets for the drain & fill plugs? If so do you have the part numbers?
Old Aug 22, 2016 | 10:03 PM
  #58
ESh's Avatar
ESh
Go to toyo diy parts catalog, put your VIN and start from there.
jennypenny
Apr 5, 2025 07:45 PM
kenEs350
Feb 16, 2015 04:46 PM
user 708235446
RX - 3rd Gen (2010-2015)
Sep 26, 2011 09:43 AM
luh1612
Feb 24, 2011 06:49 AM
jimbo22s
Jul 9, 2004 07:36 PM
