Power rear sunshade on ES350
First post here! I am trying to figure out how the Power rear sunshade supposed to work here and not able to locate anything from "search".
Here is how I "think" it should work so please tell me if I am wrong.
1) Reverse - Power rear sunshade goes down automatically.
2) Drive - as soon as you hit certain mph, Power rear sunshade goes up automatically.
Now, 1) works all the time. It is 2) that I have problems with. It seems that it only goes up by itself once in awhile, other times, I have to push the button to activate it.
Thanks for your help!
It should go up on it's own though without you having to do that so it needs to be looked at and repaired.
If you activate the power rear sunshade with the power button it should:
1- Go up and stay there if the transmission shift is either in park or neutral.
2- It will retract when you shift into reverse, and then go up if you return to either park or neutral.
3- The speed of the car should not affect the operation.
Frosty87
Sep 19, 2016 12:56 PM
