How much oil does the engine hold
Old May 6, 2006 | 05:05 PM
<VENOM>'s Avatar
<VENOM>
Default How much oil does the engine hold
I don't know if anyone is concerned with this but the owners manual seems to lack this information, so for a simple oil change how many quarts does the ES350 take
Old May 6, 2006 | 08:32 PM
dshahs420's Avatar
dshahs420
the car holds 5 quarts
Old May 6, 2006 | 09:07 PM
encore888's Avatar
encore888
Watching the ES 350 Dealer Info vid, it seems that the fluid is special Lexus 'World Standard Fluid' so the car lacks a dipstick, and requires a Lexus dealership to change the fluids...
Old May 7, 2006 | 05:07 AM
noladave's Avatar
noladave
I saw that video, and I thought that they meant tranny fluid & dipstick, not oil. Maybe I'll take a second look if only the dealer can change the oil at $100 a pop!
Old May 7, 2006 | 09:01 AM
steviej's Avatar
steviej
i believe that is the tranny fluid.
oil and filter still have to be changed by conventional means. Oil fill cap and yellow ring dipstick are still present.
steviej
Old May 7, 2006 | 12:42 PM
encore888's Avatar
encore888
OK then, thx for the correction. The video was a bit long I guess I fuzzed on the details.
Old May 7, 2006 | 02:17 PM
SilverLady's Avatar
SilverLady
steviej
I did pop open the hood at the dealer and agree they were talking about the tranny - it is supposed to be a closed system. I seem to remember a cover you need to pop off to check or add oil.
Old May 8, 2006 | 05:44 PM
<VENOM>'s Avatar
<VENOM>
thanks, 5 quarts with a filter just like the previous model
Old May 22, 2006 | 06:08 PM
<VENOM>'s Avatar
<VENOM>
just found it in the owners manual, 6.4 quarts with the filter
Old May 22, 2006 | 06:15 PM
sonyman's Avatar
sonyman
Wow that's a lot of oil for a 3.5L six.
Scott
Old May 22, 2006 | 09:13 PM
dshahs420's Avatar
dshahs420
thats a lot of oil! I hope thats not true, otherwise a synthetic oil change becomes kinda expensive. The lexus service department here told me 5 quarts.
Old May 22, 2006 | 09:24 PM
amf1932's Avatar
amf1932
6.4 quarts with filter is correct. (This figure was taken out of the owners manual).
Old May 18, 2011 | 03:39 PM
durrrr's Avatar
durrrr
There seems to be a discrepancy between what the manual says and what my oil capacity is. I have an 08 ES350 and just did my first oil change. I put in a little over 6 quarts and the dip stick shows the oil level way over the "full" mark. Can anyone confirm if this is happening to them?
Old May 18, 2011 | 07:50 PM
dreyfus's Avatar
dreyfus
A little over 6.2 quarts is what mine takes with a new filter.
Old May 24, 2011 | 05:23 AM
judd986S's Avatar
judd986S
6.4 quarts would be the TOTAL capacity. like if you ran it to get the oil warm and let it drain for an hour or two, getting every last bit out of the engine at once is tough. there will always be a little oil coating some components.
I put ~6.2 quarts in the wifes car on Sunday.
Mobil 1 5w-30
