Ambient Air Temperature Sensor Replacement
Old Mar 14, 2025 | 03:38 PM
raymgeez350's Avatar
raymgeez350
1st Gear
Default Ambient Air Temperature Sensor Replacement
Hey there. So I've had my ES since November, & the temperature readout has never worked properly. It either has no readout or thinks it's -33° or something crazy & the auto climate control tries to compensate for the "low temperature" & slowly roasts you alive. I just received a new sensor. Any ideas for installation or location?
Old Mar 14, 2025 | 04:22 PM
Gugi53's Avatar
Gugi53
The ambient temp sensor is mounted on the bottom of the crash bar, towards the driverside(see pic). You need to remove the front bumper to get access to it. It can be tested with an ohmmeter. @77*F it should read 1600-1800 ohms. @122*F it should read 500-700 ohms. If the display reads "--" then there is an issue with the sensor or it's wiring. As far as changing from Celcius to Fahrenheit, the dealer has to change that option. According to the only info i have about that, the US models were programmed to read Fahrenheit, while Canadian and other non US models were programmed with Celcius. The dealer uses the techstream to change personalized settings. There is nothing you as an owner can do to change it by yourself. I realize this thread is old with the previous posts, but figure I'd go into detail for future reference.
sderman
RX - 4th Gen (2016-2022)
13
Dec 1, 2025 07:48 PM
brotar7652
Nov 5, 2024 05:09 PM
Damar595
Jun 29, 2017 06:45 AM
mmatheny
May 19, 2016 07:01 AM
lonbon
GX - 1st Gen (2003-2009)
Jul 9, 2011 02:45 PM
