Struts
10th Gear
Struts
Hey guys I am lookin to get new struts for my car as it hits 100k miles. What strut brands should I look for as I want the comfiest ride and ride quality possible.
First determine if you really need struts as they should still be good at only 100,000 miles. See if they are leaking or fail the push test etc. How does it drive? How is your tire air pressure?
This has been discussed endlessly, There are only a few available brands. are you going to buy them and have a shop install them? It is not something that is easy to do as it requires lots of tools, and knowledge and compressing the spring is very dangerous. There are quick struts that come with the spring mounted, but they are often of lower quality. Again search and read and learn from others.
Use the search feature (box on right side of main page) and enter the word struts.
To get started see this giant thread regarding struts https://www.clublexus.com/forums/es-...y-options.html
and these https://www.clublexus.com/forums/es-...nt-struts.html
https://www.clublexus.com/forums/es-...placement.html
https://www.clublexus.com/forums/es-...n-repairs.html
https://www.clublexus.com/forums/es-...s-leaking.html
https://www.clublexus.com/forums/es-...ions-220k.html
If you ask me, Kyb Excel G.
You do not need to replace them if they are not leaking.
My car also has over 200k miles so I'm not planning on keeping it much longer. If I had 100k miles, I would put OEM quality struts. The Monroe's are not bad- they just don't last as long
Monroe are OK but too hard.
I have 130k (2010 Es350) with no leaks. Will only change if one leaks then I will change in pairs. I used to have an ES300 1997 I changed with Monroe from NAPA without any issue.
They should be changed in pairs.
Ottodrum
04-07-23 07:39 PM
