Rear Knuckle Bushing
Amayama or Ebay. I don't know if that fits your car, some Toyota/Lexus models of that era show the part separately others do not says non serviceable part. Can buy the entire control arm 48740-33100 for about $100, or aftermarket on Rockauto. You sure that bushing is bad? Don't think I've seen the inward one go bad.
I don’t believe the dealer sells it. It is tricky because that rear knuckle has like three different bushings and it is not clear if the aftermarket will be a direct fit. I did buy one from Moog Part # K201973 to have a mechanic change it since I’ve got a clunk sound from that right area, but they wouldn’t do it and said to just live with it since it is not a safety issue. I will get the whole knuckle changed down the line most likely but it is labor intensive.
Pretty sure this is it, I've replaced this bushing on a Camry. To be clear this bushing is in the knuckle itself.
https://www.rockauto.com/en/moreinfo...t=7532&jsn=396
Only way to install the bushing is bake it in an oven to 200 degrees F you'll never get it in otherwise. The knuckle also has to be warm via heat gun or at least a hot day otherwise heat will be very quickly wicked from the bushing to knuckle.
You need this one:
https://www.ebay.com/itm/18315834087...86.c101224.m-1
Part number: 42304-32050 (not available at Toyota)
TAB143
TAB143
You need this one:
TAB143
TAB143
