Engine codes: P0390, P0365, and P0345
Old Oct 2, 2023 | 04:41 PM
WBB's Avatar
WBB
2nd gear
Default Engine codes: P0390, P0365, and P0345
I have a 2007 Lexus ES350 and the other day my car would not start with the check engine light on and check VSC. The check engine came back with codes P0390, P0365, and P0345. After checking these codes, I'm assuming I have to replace the camshaft sensors. Where is the camshaft position sensor A (Bank 2), Camshaft sensor B (Bank 1), and exhaust camshaft sensor (Bank 2)? I was hoping I could do it myself instead of taking it into a shop.
Old Oct 2, 2023 | 05:26 PM
spaceballs's Avatar
spaceballs
I've not heard of both (especially intake and exhaust on bank 1) or even 3 camshaft sensors all going bad at the same time, you may want to check if there's a common wiring harness that's maybe been chewed along the way.
From this video they look fairly straightforward
, bank 1 is easier to replace than bank 2, not sure about the exhaust sensors.
Old Oct 2, 2023 | 05:40 PM
WBB's Avatar
WBB
2nd gear
Okay.....Thank you
illini19
May 21, 2022 04:20 AM
grumpy55
14
Feb 1, 2017 05:05 PM
throw
Jan 22, 2016 04:29 PM
DaveN
Mar 8, 2014 03:50 AM
lotusing
Jul 23, 2012 12:57 AM
