Clock Spring Help (need wiring diagram)
Does anyone have a wiring diagram or pinout diagram for the clock spring connectors on an 08 ES350? My CruiseControl switch is intermittent. I've ohmed out the switch under the airbag and its solid, no drop outs. I don't have 12v on the red wire going to it.
So it could be the clock spring, but before I drop a few hundred bucks to replace it, I want to make sure the connections and circuit is good up-to the clockspring. I recently had the entire dash removed for an evaporator replacemnt, so it seems equally likely the clockspring got messed up, OR a damaged wire/connector downstream between it and the PCM. I just need to know what wires are in the connectors on the back of it. So a Pinout would be best, but I might be able to go with a overall wiring diagram for the cruise control circuit.
Also, my horn and ALL other buttons work 100%. No airbag light.
Much appreciate the help in advance.
not clear what you need but here is the clock and cruise wiring diagrams. maybe you can find what you need
Edit looked up clock spring and apparently its steering related so added that
Well i'm definitely going to save these in case I need them....but they didn't get me exactly where I needed to be. Is there a diagram referencing just the cruise control circuit? Hoping I can figure it out from there.
Thanks!!
UpInTheLex
Aug 13, 2005 04:56 PM
