2014 ES 350 help
Old Oct 10, 2022 | 05:58 PM
missmae's Avatar
missmae
1st Gear
Default 2014 ES 350 help
Check engine light came on, and I could not back out of my drive way. After a quick scan I get codes p2757 and p0990. Went to local transmission shop in they quoted me 6k for a used transmission. However they could not tell me exactly what was wrong with mine. Has anyone else experienced these codes.
Old Oct 11, 2022 | 02:34 PM
mcomer's Avatar
mcomer
2014 ES 350:
code P2757 is shift solenoid valve SLU Off/On Malfunction
code P0990 is Transmission Fluid Pressure Switch "E" Circuit High
Old Oct 12, 2022 | 09:40 AM
Clutchless's Avatar
Clutchless
How many miles are on it and has the transmission fluid ever been changed? I suspect not and you probably do need a transmission. Replacing those coded parts will not solve your other problems that lead to them failing.
You should call around and get more quotes for replacement with a used transmission. I think $6,000 is too high.
Some of the used auto parts places will also do installations if there are any large foreign car yards nearby.
Old Oct 13, 2022 | 12:24 PM
jgscott's Avatar
jgscott
If was me I would 1st try 1 or even 2 drain and fills, along with 1 pan drop and filter change. Do Not do a Trans Flush.
If still a problem search car-parts or other for a low miles Trans, and a good rated shop to replace it for you at a better cost. A few years ago I helped my friend get a low miles tranny for $700 and the labor was only around $600 give or take.
mikamica
ES - 7th Gen (2019-2025)
15
Aug 14, 2023 11:41 PM
1rarees
Apr 24, 2023 08:16 AM
RKF350
20
Dec 21, 2022 03:12 PM
Rokasg23
20
Dec 29, 2021 04:12 PM
vizo09
Feb 25, 2017 06:51 PM
