ac low pressure switch
Old Aug 25, 2022 | 11:07 AM
jtolson's Avatar
jtolson
5th Gear
Default ac low pressure switch
Where is the ac low pressure switch located on my 1996 es300.
Old Aug 25, 2022 | 11:39 AM
Arsenii's Avatar
Arsenii
Hello,
It is located on the front, right between condenser and the bumper, on the Drier unit.
Why do you need to access it? They are really tough, never break.
Hope this helps and best of luck!
Old Aug 26, 2022 | 04:57 AM
jtolson's Avatar
jtolson
5th Gear
My ac comes on for a second then shuts off, checked speed sensor, control module, relay etc, compressor is working. Hunting problem, low pressure switch is fine, so I am still looking.
Old Aug 26, 2022 | 12:52 PM
Arsenii's Avatar
Arsenii
Does your AC light flash when it comes off?
How did you check the speed sensor on the compressor?
Here is a thread on how to access a Diagnostics mode for an AC system, see if there is anything stored there. Here is a similar thread on how to diagnose a speed, or compressor lockup sensor, it may have some useful information as well.
Old Aug 27, 2022 | 07:11 AM
jtolson's Avatar
jtolson
5th Gear
My 1996 does not have an auto button, so does the 96 even have codes to pull up?
Old Aug 27, 2022 | 01:16 PM
Arsenii's Avatar
Arsenii
There should be a button inside the temperature dial, below is the picture.
Michelex
Nov 16, 2023 10:46 PM
DMPesso
Aug 6, 2021 09:13 AM
4mula_J87
Jun 21, 2019 04:27 PM
Deegee
Sep 7, 2018 12:25 PM
biacs
May 12, 2017 04:48 AM
