Interior LED Bulbs
My dome light is burnt out and I would like to replace it with a brighter LED bulb. Any recommendations? I was also planning on replacing the trunk and the ones on the doors at the same time.
I like this site for finding out what bulb types a particular car uses. I generally don't like the products they sell.
https://www.superbrightleds.com/vehi...=762&year=2005
Problem I've had with DE3175, DE3021 etc. is they are supposed to be 30mm but the LED versions are usually 32 or 33mm so they are hard to fit. Do you like warm or cool white? Hopefully someone here can recommend some good LEDs for you, most I've tried frankly sucked they either didn't fit, burned out or both.
I went ahead and ordered the Philips Ultinon LED's from RockAuto for the dome and door lights. I'll see how they work and report back. They were more expensive than SuperBrightLEDs or cheap Amazon bulbs but cheaper than VLEDs.
