Lexus Multiinformation
Old Dec 13, 2021 | 04:37 PM
bernman402's Avatar
bernman402
Default Lexus Multiinformation
I cannot get the current MPG to show up on my system. I get everything but that. I must have deleted it trying to set the time. I have read the manual five times and watched videos by Lexus in Sarasoto including that display. He did say You can delete a display but did not say how. Any help would be appreciated.
the vehicle is a 2016 ES 350. Thank you.
Old Dec 13, 2021 | 06:47 PM
Kijug's Avatar
Kijug
If you mean "reset" the MPG (not "delete") then hold down the "DISP" button when displaying the MPG. After about two seconds or so, it should reset to 0. Same for the AVG SPEED.
Old Dec 14, 2021 | 01:24 PM
mcomer's Avatar
mcomer
Right steering wheel spoke, "4 square" rocker. Press the "menu" button just to the right (three overlapping pages icon).
Default Driver Information Center page is MPG. Press the left side of the 4 square to move from the Information column
to the Settings Column. Press the bottom arrow of the 4 square till you get to Meter Settings. Press the white dot button
in the middle of the 4 square and then rock down to Drive Information 1, 2 & 3. This is where you can choose what you
will see when scrolling down the information column. Note: the two MPG displays are different. "After Reset" lets me
calculate MPG by the season, I reset using the white dot button every three months. "After Refuel" is just that, shows the
results of the last 400 miles.
Advanced class on the DIC - if you would prefer the Miles to Empty (range) instead of the MPG to be the default screen when
you first press the right steering wheel Menu button? Press the 4 square down once to show Miles to Empty and then press
and hold the Menu button. When the dialog box pops up "do you want to change to "this" screen? Yes. Now when you press
the menu you'll get range and can scroll for the various MPG readings.
StevenTodd
Sep 20, 2020 04:48 AM
lexyluv
Aug 20, 2014 10:57 AM
cbrewer
Feb 17, 2009 01:39 PM
