HID replacement issues
Old Oct 9, 2021 | 03:44 PM
Joeland's Avatar
Joeland
10th Gear
Default HID replacement issues
I just replaced my HID low beam on the passenger side of my 2002 ES 300. I ordered two Philips bulbs that were to my knowledge, new. Each one when installed lit up only 3/4 as bright as the light that hadn’t gone out, flickered a bit for maybe a minute, and then went out.
Did I burn through both and the bulbs were faulty, or does it seem to be an installation issue? I am confident I installed them correctly.
Does it matter than the battery hadn’t been disconnected first?
Thanks in advance to anyone that may have useful input.
Old Oct 9, 2021 | 07:08 PM
Don't need to disconnect the battery, the light switch being off is the same thing. Maybe the ballast burned out? Put the original bulb into the other side see what happens.
poorkidlol
Dec 10, 2010 09:57 AM
awilling
Aug 29, 2008 11:23 PM
cm09578
Lighting
Jan 24, 2008 09:29 AM
GS300.ru
Nov 14, 2001 11:53 AM
