Help with part
Hello,
Here you can find all the Part Numbers for your car. It is a Cowl to Hood Seal, Part Number for which is 53383-33040. That said, the rubber itself in your case appears to be fine, so you only need the clips that hold it in place, P/N for those is 90467-08101. Your best bet would be to look for such parts at the junkyard, since they can get expensive fast at the dealership, and it usually takes a while for parts that are unique to the car to arrive.
Hope this helps and best of luck!
Hello,
