whiny power steering pump
Old Jan 26, 2021 | 09:28 PM
ccarruth's Avatar
ccarruth
Default whiny power steering pump
I've put in 2 pumps...both whine. I don't remember the whining before. It only whines if the steering is engaged. Not low on fluid, No change in steering control. Wat brand of pump can I put in that doesn't whine? Wife refused to drive. 2003 ES300.
Old Jan 27, 2021 | 09:07 AM
What brand(s) did you use? FYI aftermarket hoses especially the high pressure line can cause this it happened to me.
Old Mar 16, 2022 | 12:44 AM
jdang0118's Avatar
jdang0118
how did you find out what the issue was. I found out the dealership put in an aftermarket pump. Could that be the issue as well?
Old Mar 16, 2022 | 04:49 AM
ES300TX's Avatar
ES300TX
Wow. It seems more and more dealerships are actually doing that. It used to be that you could count on a dealership at least using quality parts. That doesn't appear to be the case.
Old Mar 16, 2022 | 07:44 AM
Need more info. What year is your car? What part was used exactly?
In my case I found a used line (salvage yard) which cured the whine. This was on a 1996 ES300 (I think) not 100% sure I work on a lot of cars. Also had this happen on my own car 1987 Camry.
Dynasty30
Jan 28, 2021 04:17 PM
overclock
Nov 12, 2020 12:33 PM
Dx3
Apr 7, 2013 07:36 AM
redgs300
Sep 23, 2012 06:43 AM
trk1
Mar 30, 2011 06:32 PM
