2004 ES 330 Sonsor problems
Old Jun 11, 2020 | 02:05 PM
Wessam's Avatar
Wessam
Default 2004 ES 330 Sonsor problems
I have Es 330, 2004 with an error code P2241, bank 2 sensor 1.
Any advise to fix it myself and where is the sensor located?
If I have to buy it any recommendations as i tried from Amazon but i find sensor 2.
Thanks a
lot
Old Jun 11, 2020 | 06:45 PM
Arsenii's Avatar
Arsenii
Hello,
If I understand correctly, P2241 means that the data sent by Air/Fuel Ratio sensor is lower than ECU expects. It is probably just a bad Air/Fuel Ratio sensor, in your case, it is the one towards the radiator. To make sure, you can warm-up the car, and then take a look at the ECU's live data - A/F sensor output should be around ~2.9-3.3V.
Hope this helps and best of luck!
Dschwartz
Mar 10, 2020 02:28 PM
edstofegaj
May 18, 2015 01:08 PM
