Limp mode? (Codes included)
2000 ES 300
This car has been bulletproof for me@190k miles now. All of sudden I'm getting misfires and all of these codes and it will rarely go into gear, if it does you can drive about ten feet in either one of the gears before it stops.
P0305 - Powertrain
Cylinder 5 Misfire Detected
P0330 - Powertain
Knock Sensor 2 Circuit (Bank 2)
P1130 - Powertrain
P0503 -Powertrain
Vehicle Speed Sensor:Intermittent /Erratic/High
P0128 -Powertrain
Coolant Thermostat (Coolant Temperatur Below Thermostat Regulating Temperature)
Currently looking for another vehicle. Would be interesting to hear opinions on what might be the problem?
P0305 - Powertrain
P0330 - Powertain
P1130 - Powertrain
P0503 -Powertrain
P0128 -Powertrain
That's a lot of codes the misfires could be caused by bad VVT oil control valves, worn plugs, bad coils, vacuum leaks. Knock sensor is probably like it sounds knock sensor not working. I'd replace the thermostat first and go from there. Also have the battery and alternator load tested.
skye2388
Dec 8, 2013 07:22 PM
