adaptive variable suspension question
Old May 31, 2019 | 11:43 AM
Efabe420's Avatar
Efabe420
Default adaptive variable suspension question
My rear shocks are toast in my 06 ES330 and Ive been shopping around but they all seem to say W/O or excludes adaptive variable suspension. I don't have a "sport/comfort" switch but there is a VSC light that illuminates if the CEL is triggered. So I'm assuming it has some kind of stability control but I just don't know if it has the aforementioned "adaptive variable suspension". Are these systems one in the same, switch or no switch?
Old May 31, 2019 | 11:51 AM
VSC and adaptive suspension are two different systems they are not related. Need to read the code(s) to find out what the fault is mostly likely a bad ABS sensor.
Old May 31, 2019 | 11:57 AM
Efabe420's Avatar
Efabe420
Thank you for quick reply and for clarifying that for me. The VSC light isn't on now, I was simply pointing that out for informational purpose. Im trying to figure out if these shocks that "exclude vehicles with AVS" will work on my car
Old May 31, 2019 | 12:03 PM
On the 3ES you can swap in standard struts in place of the AVS versions I'm quite sure on your car this is the same.
Old May 31, 2019 | 12:19 PM
Power6's Avatar
Power6
If you don't have a console switch with "sport" and "comfort" you don't have the AVS. The w/o AVS stuff is for you!
AlanLS430
Nov 29, 2017 01:22 AM
rklages
GX - 1st Gen (2003-2009)
Jul 9, 2007 10:58 AM
mjc68
May 30, 2007 07:29 AM
Sal Collaziano
Sep 3, 2005 05:14 AM
Bobhgd
May 12, 2004 10:29 PM
